Clicking noise when I hit brake, need help - AudiWorld Forums
Old 03-13-2009, 10:51 AM   #1
New Member
Default Clicking noise when I hit brake, need help
Hi,
I need help if someone ever experienced the clicking noise when you hit the brake, when I drive slow and start hit the brake I heard clicking (just one click, everytime I hit brake) noise that I can hear inside the car. The sound came from the front passenger side wheels, but I noticed there's nothing leaking or torn in front axles, Is it the wheel bearings goes bad that made the sound or something else? Thanks for your help.
Al
al1375 is offline   Reply With Quote
Old 03-14-2009, 03:45 AM   #2
crap stuck in the brake pad?
EBG 18T [Eric] is offline   Reply With Quote
Old 03-14-2009, 11:49 AM   #3
TurboEnvy52's Avatar
Default Front passenger wheels? you ahve a 4x2? lol
Just sounds like some sand in the brakes...hit them hard one or two times, see if it stops!
TurboEnvy52 is offline   Reply With Quote
Old 03-14-2009, 03:29 PM   #4
Default See my post down below....
You may have a brake pad come loose from the backing plate and this will give you a click.
Bob Petruska is offline   Reply With Quote
Old 03-27-2009, 03:25 PM   #5
does it sound like a clap? i think i have the same sound,everytime it happens, i imagined a clap between the brake pad and rotor, but im not even sure if thats the actual cause of the sound.
rmonster is offline   Reply With Quote
Old 03-27-2009, 09:42 PM   #6
s4master1's Avatar
have you replaced the pads recently?
did you use aftermarket pads?
we see this type of sounds a lot and usually is the pads been shorter than the original parts
s4master1 is offline   Reply With Quote
Old 03-28-2009, 12:01 PM   #7
Have you checked all the suspension bushings? I just had my car in with roughly the same noise, only at slow speed, and they replaced to 2 bushings and the noise is completely gone.
Not a cheap fix FYI.
grocery getter S3+ is offline   Reply With Quote
Old 03-30-2009, 12:56 AM   #8
New Member
I had a similar click in my car, and I checked everythin, but all was OK, untill one day, brake light came on the cluster, so I checked the brake fluid and the level was low. I refilled it, and since that day I never heard that click anymore. try this
Arimendiii is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
When to replace shocks and struts - Wobble at 20mph/40mph ZPA117 A4 (B8 Platform) Discussion 4 09-08-2015 12:55 PM
Audi Fix for Brake Noise? ILTRAVELER Q5/SQ5 MKI (8R) Discussion 0 09-06-2015 09:56 AM
How do you launch your S6 or 2.7T? LaserSVT A6 / S6 (C5 Platform) Discussion 6 09-05-2015 09:40 PM
:: ECS Tuning :: Assembled by ECS Audi B6 A4 1.8T Quattro Brake Service Kits. ECS Tuning-Audi A4 (B6 Platform) Discussion 0 09-02-2015 12:39 PM
Got an A7, wanna ask some questions :) zhaoweitian A7 2 09-01-2015 04:15 PM
Tags
2006, a4, a6, audi, brake, brakes, braking, breaks, click, clicking, hear, hit, make, noise, tt
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
