Diesel sound like when gear engaged
Hi
I've been dealing with many issues on my A4 2003 1.8T Quattro Tiptronic since I bought it in October, last year.
To make it short, have changed timing belt, accessory belt, water pump, idler, coil packs, spark plugs, cam tensioner, diverter valve, and most of pipes and valves related to water and vacuum. It all started with a couple of error codes one related to the cam tensioner and the other to the thermostat. After a while realized it was just a fuse.
Anyway, the car had improved its performance, as when I got it, barely made it to 60mph. Now I can get into 80-85, but with a lot of pressure on the accelerator. Mileage is awful, around 14-15 mpg. In addition to all that, it is making a noticeable diesel like kind of sound, but only when the gear engages, and knocking noises when under load at low speeds. Like going uphill in a crowded neighborhood.
This problem seems very complex, from my point of view, and never expected when I bought it. I can drive the car around, but definitely have to do something with it
Would appreciate if anyone has seen problems like this and suggest previous posts that may address this situation.
One situation that may or may not contribute to the problem, is that one of the lower suspension came loose and pulled the entire axle out of its position, which was rebuilt to get it back in.
Again, appreciate the help!
Today I realized that when gear engages, the entire engine shifts forward about a quarter of an inch, and that's where the sound starts.
Could it be the engine support or the gearbox?
haaghala
A4 (B7 Platform) Discussion
04-07-2019 10:56 AM
spiralsmurf
Audi Original "S" Cars
07-16-2006 02:39 PM
JonRS4
06-27-2003 09:38 AM
