DIY: Easy Cracked Radio Reciever Fix
Old 08-09-2011, 06:09 PM
Albert_3.0's Avatar
Default DIY: Easy Cracked Radio Reciever Fix
This is actually a DIY for something I did two years ago. Better news: radio on my car has been working perfectly for the past two years.
So as many of you know, this receiver is known to have the issue of cracking when exposed to lots of heat. Unfortunately, this cracking makes the receiver useless. So if you're receiver has cracked, don't go to the dealer and pay an arm and a leg to fix the receiver. This DIY should do the trick.
Supplies:
A few small bulldog clips.
Procedure:
1. Remove the rear trim
To do this, you will want to pull at a corners of hte trim. You have to pull pretty hard to get the trim off.
2. With the rear trim off, you will see the receiver. It's long, thin and black with three hookups on the right and and another in the middle. Leave these cables on and pull the receiver off. We will need the cables to be attached for the later part of this fix.
3. Now its time for some experimentation. With the radio tuned to a station you know has STRONG reception, apply pressure to areas around the edges of the receiver. Do this with your finger. You should notice that when you press certain locations, the signal will become much stronger. Keep these location in mind.
4. Take the bulldog clips and use them to clamp down on the areas of the receiver you noted in step 3. These bulldog clips will apply constant pressure to the receiver and also hopefully fix your radio.
Here is what your finished product should look like:
<a href="http://s1232.photobucket.com/albums/ff375/albertkim92/?action=view&amp;current=5e783e22.jpg" target="_blank"><img src="http://i1232.photobucket.com/albums/ff375/albertkim92/5e783e22.jpg" border="0" alt="Photobucket"></a>
Old 08-10-2011, 02:02 PM
greenwheels's Avatar
Default Thanks for the photo
Thanks. I have found that applying pressure in the region you show does make the amplifier work so I'll try the bulldog clips. Looking at the unit it seems that the black rubber/plastic is there as a protection layerand that it does peel away so if all else fails I'll take the black rubber off and see what is underneath. If nothing to be donne ther, the white connector has the FM signal and seems to be OK with a metre of wire draped along the parcel shelf.
Supplies:
Procedure:
Old 08-15-2011, 05:08 PM
Bob Petruska's Avatar
Default That fixed mine!
Thanks for the information and photo.
Saved me $254!
Bob P.
Old 08-16-2011, 05:49 PM
BSCA4's Avatar
Where is this receiver in my 03 Avant? My AM signal getting worst over the year.
Old 08-17-2011, 09:37 PM
Albert_3.0's Avatar
Hmm. I'm not sure on an avant. Possibly the upper rear trim area?
John O'Hara
04-03-2013 02:39 PM
McBadger
A4 (B7 Platform) Discussion
03-24-2008 12:27 PM
philbyil
12-14-2004 08:28 AM
DantheGerman
11-06-2003 01:15 PM
King_Quattro
12-28-2000 09:14 AM
Quick Reply: DIY: Easy Cracked Radio Reciever Fix
