Emergency or warning triangle compartment case lock
Old 09-03-2015, 11:42 AM
kjmiles's Avatar
Default Emergency or warning triangle compartment case lock
Awhile back, the piece holding the door closed to my emergency triangle in the trunk lid that attaches to the **** you see and probably have rarely if ever used broke (the part number is 4B98678994PK - they call it an escutcheon). The **** was fine, squeezed hard with a pair of needle nosed pliers on the tab on the back which goes through the escutcheon, and the two parts separated. The list price on that part is $26.12 (8/2015) and with the **** is $21.08! The whole emergency compartment assembly is like $300! Crazy. Anyway, in doing my research on alternatives (other than a zip tie, which works, too), I found this on Audizine: Search Thingiverse - Thingiverse
It's a link to a 3D printer file and sure enough, works like a charm! A friend of mine printed it for me and it's probably better than the original part. If you have access to a 3D printer, this will solve the compartment opening every time you open the trunk!
Just wanted to share the wealth.
KJ
Old 09-04-2015, 03:55 AM
lyleswk's Avatar
Good info. Wish I had access to a 3D printer. Now only if someone would do something similar for the glove box!
Old 09-04-2015, 04:01 AM
lyleswk's Avatar
uble1234
14
10-23-2020 08:07 PM
Quick Cal
4.2 V8 Discussion
06-25-2018 07:57 AM
Tman007
A7
10
10-01-2015 07:25 PM
KekePerkele
09-28-2015 09:29 AM
craigandjenn4
Q5/SQ5 MKI (8R) Discussion
09-27-2015 01:57 PM
Quick Reply: Emergency or warning triangle compartment case lock
