Error code P0411 secondary injection flow low - AudiWorld Forums
Old 08-03-2007, 02:03 PM   #1
Default Error code P0411 secondary injection flow low
I have a 2002 A4, with 62K miles. recently i started getting a CEL with error code P0411. I reset the error code a couple of times hoping it was false trigger but it keeps coming back.
Any suggestion what I can do to fix the problem (other than taking the car to the dealer).
people suggested checking for cracked hoses that come off the air pump. The problem is I donlt knwo where the air pump is
Any suggestion would be greatly appreciated.
thanks
NickAudiA4 is offline   Reply With Quote
Old 08-03-2007, 02:18 PM   #2
Senior Member
Default I got the same thing recently, and the code came back this morning.
I thought the hoses for this at approx 11 O'clock as you are standing in front of the car looking down at the engine, but I'm going to check my Bentley this weekend to find out for sure.
Bronze is offline   Reply With Quote
Old 08-03-2007, 02:47 PM   #3
Default forgot to mention a weird noise every time I start the car
I forgot to mention that recently, every time i start the car it makes a weird noise. It sounds like a motor that is trying to open or close a valve or something. Can it be the air pump failing?
Old 08-03-2007, 02:52 PM   #4
New Member
Default A few things to check in the morning (cold engine)
Listen for the secondary blower to run (100 seconds after engine start-up). This sends air to the cyl head via the EGR valve. Make sure the vac hose going to the EGR valve is intact. Make sure all the plumbing for the secondary air pump is in order.
Possible problems include a plugged up EGR (combi-valve) valve, a bad secondary air pump, blown secondary pump fuse.
Let me know. Have a great weekend.
kevinr is offline   Reply With Quote
Old 08-03-2007, 03:00 PM   #5
Default Re: A few things to check in the morning (cold engine)
Because I am new to this, can you give me an idea where the secondary air pump is located?
once I find that I can trace all teh hoses and check for any cracks.
Old 08-03-2007, 03:08 PM   #6
New Member
Default below the air filter box, next to the turbo/inlet hose, in front of the RF wheel
it will have two plastic hoses going to it (inlet/outlet) trace away
Old 08-03-2007, 03:25 PM   #7
New Member
cold engine or warm/hot? Normally the secondary AP only runs on cold startup
Old 08-03-2007, 03:30 PM   #8
AudiWorld Uber User
Default My car has been doing that for the last 12 months or so.
I said, fvkc it, I'll fix it when it breaks.
Tgr_Clw is offline   Reply With Quote
Old 08-03-2007, 03:44 PM   #9
Default Re: cold engine or warm/hot? Normally the secondary AP only runs on cold startup
it does it early in the mornign .. when the engine is cold from the night.
It's being making the noise for some time now. You think it's ok to wait until something breaks like Tgr_Clw did?
Old 08-03-2007, 03:59 PM   #10
AudiWorld Uber User
Default Please don't listen to me, I'm a complete n00b when it comes to engines and moving parts.
I simply never got around to checking what that sound was and since it doesn't seem to be getting any worse, I've decided to leave it.
Thread Thread Starter Forum Replies Last Post
I have some fault codes and an engine light car stalled turned off saifxnyc A6 / S6 (C6 Platform) Discussion 9 11-30-2015 01:32 PM
Turn Signal Switch Problems Kongen A4 (B8 Platform) Discussion 1 09-17-2015 01:23 PM
Can 00604 - Potentiometer Positioning Motor for Air Flow Flap cause no heat? ajg617 A6 / S6 (C5 Platform) Discussion 0 09-06-2015 08:23 AM
No Start, Need Codes Diagnosis eggsngrits A8 / S8 (D3 Platform) Discussion 0 09-05-2015 11:22 AM
Frustrated 2004 Audi A8L 4.2L jeffkruse A8 / S8 (D3 Platform) Discussion 5 09-04-2015 12:59 PM
Tags
00, 01, 1999, 411, a4, a6, audi, code, error, head, makes, p0411, plugged, po, po411, quattro
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
