hey northern guys are you aware of frozen brakes?
Old 12-17-2007, 04:20 AM
seencats's Avatar
Default hey northern guys are you aware of frozen brakes?
i was on my way to the dealerhisp this morning and as soon as i backed out of my driveway i felt something wrong with my brakes. I wasnt sure what it was but it felt as if my e-brake was up(but it wasnt)i drove down the street and luckily my mom was behind me and told me to pull over as she smelt something burning. As soon as i got out i saw the back brakes smoking. I spoke to my advisor adn he was laughing because he too had a smiliar promblem coming to work this morning as well, but not as bad. I had no clue that this could ever happen. He told me just let them thaw out and everything should be fine. Has anyone else heard something like this?
Old 12-17-2007, 04:28 AM
x1rider's Avatar
Default I had it happen in the winter of 2004...
we were seeing -40F regularly and I had the bad habit of leaving my e-brake on overnight. I'd have to slip my clutch like crazy to take off and as soon as I'd let off the throttle, the rear wheels would lock up and I would start sliding sideways.
Old 12-17-2007, 04:29 AM
Member
QuattroFan02's Avatar
Default Yes very common. These cars have a poor e-brake cable design that freezes.
No real fix to it, just drive it until it warms up enough and it will be ok. For future reference, don't set that e-brake and just leave the car in gear if you know that overnight temps are going to be below freezing.
Old 12-17-2007, 05:06 AM
diagnosticator1's Avatar
Default The latest PN version for the cables is supposed to address water getting into the cables...
and prevent this from happening. If there is water inside the cables, the ebrake cannot be used in freezing weather, therefore is justified warranty replacement, or worthwhile as a paid item if no warranty. "Thawing" the cables is only temporary, as the water will not dry out otherwise, and additional water will get into the original cables anyway.
Old 12-17-2007, 05:55 AM
seencats's Avatar
what is PN?...thanks everyone for your feedback!
Old 12-17-2007, 06:42 AM
AudiWorld Uber User
Tgr_Clw's Avatar
Of course. I don't use my e-brake when the temps are below freezing mark.
Old 12-17-2007, 07:14 AM
OLight:TNG's Avatar
"Part Number" - right?
Old 12-17-2007, 07:48 AM
Yes.
Old 12-17-2007, 03:04 PM
Default When this happens on my '03, I use a 2X2 about 2' long, and lever the ebrake arm on the caliper...
back towards the front, using the wheel as a pivot point, to release the ebrakes. The ebrake lever in the cabin must be released first.
I recommend against driving with the ebrakes frozen ON, as loss of steering control is possible, due to the wheels locking on ice.
Old 12-17-2007, 08:46 PM
Audi Junkie's Avatar
Default -40f is pretty serious cold. Do you use a block heater? Dumb question. One thing I do w/ the trans
with the manual trans is to leave it in 2nd gear overnight, to avoid that 1->2 cold shift. I can drive pretty far in 2nd until I need to shift.
Quick Reply: hey northern guys are you aware of frozen brakes?
