Horrible radio reception - AudiWorld Forums
Old 07-18-2011, 07:50 PM   #1
Default Horrible radio reception
I just got a 2004 A4 1.8T and the reception of the radio is horrible. I upgraded to this vehicle from my old 1997 A4 and always had great radio reception.
All the same local stations I listen to in all of my vehicles but its mostly static.
Is there something I am missing here or something I can do to improve this?
Thanks
spleify is offline   Reply With Quote
Old 07-19-2011, 09:29 AM   #2
Check the antenna connection at the back of the radio. Reception is great on my 2005 & 2008 A4's. Had a 1998 A4 in the past and can't say there is any difference in my received signals between all 3 cars.
A4Audi4Fun is offline   Reply With Quote
Old 07-19-2011, 05:15 PM   #3
Ok I will check it, is there a special tool required to pull the radio out or a special way it needs to come out. Do I need to pull it out, or can I get to it with out pulling the radio.
Old 07-19-2011, 07:06 PM   #4
Search for Audi Radio Keys - ebay has some for $3.99. It might be possible to reach in behind the console to reseat the radio antenna cable; never done that before on an Audi but have a try from under the dash.
Old 07-19-2011, 10:06 PM   #5
Does the car have aftermarket HID's? If yes, does the bad radio reception only occur when the lights are on? If yes, that's the problem...you have to kinda, live with it.
If its occuring ALL the time, check your FM booster, its at the top of your rear window under a panel, you can do a search on the issue, if its cracked, you need to replace...$110.00 bucks, give or take, or if cash is short, now that you know where it is, go to a junkyard and pull one out of a crashed B6.
ggcrash is offline   Reply With Quote
Old 07-20-2011, 05:49 PM   #6
woofster's Avatar
I went from a B5 to a B6 as well and I never noticed a big difference. In fact, I think the B6 radio might actually have better radio reception than the B5 did.
woofster is offline   Reply With Quote
Old 07-21-2011, 07:30 AM   #7
So after reading about 20 different threads now, I have realized this is a very common problem with the antenna booster above the rear window (like also mentioned by ggcrash).
I am gonna pull off the panel and see if mine is cracked, just an FYI though, they are about $300
From what I have found it seems this was a problem with the earlier B6's and might have been resolved in the later models as Audi realized they were installing a POS
Thread Thread Starter Forum Replies Last Post
Fault Codes Kerry G Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 06-07-2016 03:55 AM
Need help (radio screen) 2121hamm A6 / S6 (C6 Platform) Discussion 1 04-24-2016 01:09 PM
Radio Volume NightBlue4.2 A6 (C7 Platform) Discussion 12 02-12-2016 04:19 PM
Help with 2005 Audi A6-3.2L quattro BKH bballfreak A6 / S6 (C6 Platform) Discussion 4 10-12-2015 06:14 PM
Car Completely Dead: No Power gakor A4 (B6 Platform) Discussion 1 09-27-2015 03:10 PM
Tags
2002, a4, a6, antenna, audi, b5, b6, beetle, booster, c5, fix, improving, problem, radio, reception, vw
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
