Installed HID kit, plagued with dash display problems
#11
The canceler is just a 5 ohm 50ish watt resistor enclosed in a plastic case. The resistor "fools" the CAN system into thinking there's still an incandescent bulb there by providing the correct resistance of an incandescent bulb.
Course, putting a small 194 bulb has the same effect as a cancelor, and costs a lot less ;oD
#12
Can you reproduce the faults in park? Or does it only happen on the road after some time?
It almost sounds like it's grounding out a power wire going to the headlights. If it were a ground, I wouldn't expect that many faults, but a power wire might lead to other faults.
Or perhaps it's Audi's way of making you pull off the road to correct it immediately... Throw a christmas tree's worth of lights onto the dash.
#13
Hello,
i worked at audi dealership for 4 years and it is true that when you install a cheap hid kit on recent audis, you have a lamp out error. On saturday and sunday, i rent a small garage spot to do jobs and hid kits are really popular. After a lot of research, the only kit that will not do you any lamp out error on the dash is the canbus ballast 55w. Since i know this, i order to all my customers the canbus ballast 55w hid kit and till now, i didn't get any problem with them. The price is average but the quality is really good. I dont have any flickering with DRL, no lamp out error and no need of relay. I buy them on www.xenonhidconversionkit.com
i strongly recommend everyone with an audi to buy their hid kit on this website.
William
William
#14
Hello,
William
William
#16
fix 4 u
I installed a 55w HID kit from Retro-Solutions and have been experiencing electrical problems ever since. One out of five times I turn on the headlights, I get one of the following:
I've attached a picture of my dash on the way home from work today. At about 50mph I turned on the lights and the warning chimes went off, warning lights flashed (traction control, ABS, parking brake), and the speedo went dead. When I got off the highway I was able to turn the car off and restart at a stoplight which returned everything to normal.
This is really odd and I'm pretty sure its the lights or the way they're connected to the car. I didn't install myself, so I couldn't tell you how they're wired in. Has anyone else run into this issue installing a HID kit? Any ideas how to remedy?
- Warning message on dash of 'dipped headlight'
- Warning message on dash that bulb is out, and one of the headlights will be off
- Literally every dash warning light comes on and the display chimes at me
- Every dash warning light comes on and the speedometer crashes out
hi there.
i had this exact problem and it is all due to electro-magnetic interference (EMC) due to the ballast on the left side (abs module on that side).
what you need to do is, find yourself some quality copper grounding wire.
undo a screw on your left ballast, mount the wire to the ballast and fasten it down with the screw, i personally pinched it between my ballast' case. take the other end of the wire & mount it between the washer and the bolt of the washer fluid bottle.
problem solved.
some kits come with emc bits and bobs, they're good but unreliable.
put a relay on your kit & ground the left unit then you should be all good.
good luck!
#18
#19
Things like this should not be happening 5 years later, technology with ballast have gotten a lot better.
We have built in error cancelers and casing to prevent any radio interference you normally see with some ballast. We feel if you are having the issue it is a cheaper HID ballast that are not spending the money to put all the newer technology into the ballast.
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
blackbart
10-17-2004 11:34 AM
