Need help from Audi experts on the car heater coolant please?
Thanks to the forum I managed to find the root cause of oil in my coolant as the O-ring seal on the oil cooler which I have now changed and the problem is fixed, however I am now having a slight issue with the car heater maintaining heat?
When I changed the oil cooler, I thoroughly flushed the coolant hoses with hot water through a hose for 30 mins, getting hot water through different combinations of disconnecting hoses until the water ran clear. I also removed the expansion tank and thoroughly cleared it out with mild soap until clean and I have flushed the car about 3 times in total.
The issue is the car starts to get warm okay after 3- 5 mins of driving but goes cold at the lights etc and does not get properly warm and maintain the heat until about 15 mins?
I have read forum posts stating that the heater core is blocked and needs flushing , however I have done this 3 times very well and there is no restriction at all when I run the hose through it?
I have bleed the system by undoing the small screw on the metal pipe whilst lifting the expansion tank high and there was some air and then once water came out sealed it.
I have pulled back the outlet pipe at the heater core when it was hot and water came out of the little hole so this should tell me there is no air there too? (PS does it matter which hose I pull back inlet or outlet?)
I am bleeding the car wrong? Do I need to bleed the system when its cold or when its at the operating temperature?
PS Although before when I had oil in the coolant from the bad oil cooler the heater was working fine so this is why I think it’s an air lock somewhere?
That happens when you have stuff in the cabin heater jamming it but you said you cleaned it up.
You must have an air bubble in the heater. Here's one way of dealing with it:
Fixed my "no heat" problem.
chenishead
07-08-2008 11:08 AM
GDA4
12-19-2005 06:29 AM
Corey
12-14-2005 08:43 AM
Roamer
12-20-2001 05:47 AM
