Oh you know just another weird coolant issue
Sorry for yet another coolant trouble post, I've spent the last 3 hours reading every thread about overheating issues,
Here's my situition.
1. 2 weeks ago car started to overheat while getting on the freeway(was an uphill entrance) after some browsing on different threads I assumed it was the waterpump, replaced that and after some purging of the coolant system it was good.
2. Couple days later I make 200ish round trip everything goes smoothly,
3. After a week of sitting I jump on the freeway and its started overheating again,
1. Upper and lower radiator hoses are hot,
2. There's no visible Coolant in coolant; nor coolant in the oil,
3. I get tiny amounts of heat when I first turn on the heater then quickly goes cold(I already know heater core is clogged) it's been like that for over a year.
4. There's no smoke from exhaust when idling
Here's where things get interesting.
1. I assumed it was the thermostat but from my understanding the Lower radiator hose would be cold if the thermostat was stuck closed.
Edit: I tried to purge the coolant system,
Ran the engine for 20-30min with coolant tank cap off,
And every time the fan kicked on the system would bubble over and release tons of air bubbles, then once fan turned off it would stop,
It seems that it's the waterpump but I replaced it with metal impeller less than a month ago, it was ecs waterpump.
Any idea on what it could be, since the fans turn on, and doesn't overheat when idling.
Meaning I ran the car with the cap off for over 20 minutes and multi able times the fans kicked on and it boiled over, once fans shut off it stopped boiling over.
Any suggestions on what it could be?
If I had to gues my coolant to water ratio is 25/75 or 30/70
Meaning I only have 25% coolant in there the rest is water.
The mixture amount shouldn't make a difference. I would run it with the fan on and see if it does the same, i.e. boil over. The system is intended to run under pressure. You may have something as simple as a leaky cap...
Edit: would follow the other thread just now going active on coolant.
We are talking about 1.8T right? These cars are getting old enough now that radiators do plug up inside and cause them to run hot. Also alot of debris, leaves ect can build up between the radiator and a/c condensor and kill airflow. You could try the thermostat. They can fail and just not open 100% and then restrict coolant flow.
SFexBOY
02-18-2008 05:03 PM
ravidrabbit
06-19-2003 12:07 PM
SugarRushAudi
05-28-2003 04:41 PM
