Oil in spark plug
Oil in spark plug
Hey guys need to the site. I have a problem with my 2004 a4 1.8.
I fould oil or coolant in the coil pack/ spark plug. I just changed the valve cover gaskets about a month ago. I snapped a picture so i need your help, not sure if i have a cracked head or not, what do tou guys think?
Is the engine running OK otherwise?
If this turned up at my place without knowing the history, I would be installing a new valve cover gasket. There is no coolant in this area so assuming its just oil. I would replace the gasket again (relatively cheap item), paying particular attention to both surfaces are very clean, valve cover is not warped, torque down the cover evenly, check for distortion of the cover etc
I am not a big one for using gasket adhesive but in this case, since the gasket was only done a month ago, if you don't see any reason for the failure I would consider a purpose adhesive.
Just my opinion.
Just my opinion.
Could just be residual oil from before you changed the gasket. Clean it out and then reinstall the plug. Check it again in another 3-5K miles. If its back you may have installed the gasket incorrectly. If not. I wouldn't worry about it.
Jason
Jason
tuneda4
1.8T Discussion
04-01-2008 04:54 AM
escargot
Audi Original "S" Cars
10-23-2004 10:00 AM
