One of two key fobs not working
I dug an old key fob out of a drawerdrawer, put in a new battery, but it's still not functioning. The other one works fine. I tried the reset procedure from the manual, but nothing. I deduce from this that the fob itself is bad, or is there something else I can try? Thanks.
That happens to most people who mainly use one Fob. What works for me is I put my key in the ignition, switch it to the on position without starting it, then press and hold down the lock button ( or the unlock button, I can't remember?) on the FOb for 5 seconds. Turn to off position, remove your key then test the lock/unlock buttons. Is that the procedure you tried?
You will have to get the key sync'd with the immobilizer on the car and my understanding is that only the dealer can do this. It will run you another 100 to 150 dollars...
johash
TT (Mk2) Discussion
10
12-06-2020 09:28 AM
MikeM3412
14
02-24-2018 08:19 PM
CobraCommander
09-30-2016 05:11 PM
SYMAWD
A4 (B9 Platform) Discussion
05-19-2016 09:15 AM
