Sudden jerking after deceleration then pressing on throttle.
Old 12-05-2013, 07:58 AM
Andrew.castaneda89's Avatar
Default Sudden jerking after deceleration then pressing on throttle.
I have a 2002 a4 3.0 with the automatic/tip trinity transmission, around 65k miles. The problem occurs when I'm slowing to a stop, normally around 1k Rpms. The auto/tip will either jerk right before it downshifts; or let's say I'm coming to a red light that suddenly turns green, I'll let off the brake and press the throttle, occasionally it will hesitate and jerk into gear. When I bought the car 3 months ago I was experiencing this problem, so I changed the tranny fluid and filter, but still the problem persists. Help, anyone?
Old 12-05-2013, 07:59 AM
*tiptronic not trip trinity... Autocorrect
*tiptronic not trip trinity.. Autocorrect
Old 12-05-2013, 10:49 AM
lyleswk's Avatar
Download codes?
Old 12-05-2013, 10:53 AM
Originally Posted by lyleswk
Download codes?
It's not throwing any and I don't have a vagcom
Old 12-05-2013, 11:09 AM
lyleswk's Avatar
You don't know if it's not throwing Audi codes unless you have a VAGCOM. The generic readers only read a subset of the codes an Audi. It may be throwing a tranny code that doesn't trip the generic reader.
Old 12-05-2013, 12:10 PM
Yea I've been looking into getting one. Anything I can do outside of that?
Old 12-05-2013, 12:43 PM
lyleswk's Avatar
Everything would be a guess since you have replaced the fluids. You could take to an indie or a dealer with a VAGCOM reader.
Old 12-05-2013, 12:52 PM
Maybe a Xmas gift to myself. Luckily it happens only occasionally. Thanks for the help.
Old 12-13-2013, 09:50 AM
tofast2belast's Avatar
not sure if the auto models do this but on manual the brake test circuit switch can cause similar problems. such as while sitting still and getting ready to move, the ecu will cut the throttle until you release the gas pedal. this occurs when the switch starts failing.
Quick Reply: Sudden jerking after deceleration then pressing on throttle.
