How much to change a tempature sensor
Old 01-29-2014, 07:13 AM
audia4turbov8's Avatar
Default How much to change a tempature sensor
My 2002 a4 1.8t keeps throwing codes for the tempature sensor and it turns off the abs and traction control until I turn off the car and restart it is it expensive to replace or should I wait until I do the timing belt
Old 01-29-2014, 07:43 AM
greginfinity's Avatar
Which one? Do you have the code? I just did mine, used this writeup:
https://www.audiworld.com/tech/eng66.shtml
It is pretty simple, just take your time to make sure you get it seated correctly. It would take an indy shop an hour plus sensor cost.
Old 01-29-2014, 08:53 AM
[/B]
I don't have the codes I'm going to get them tonight what happened to your car before you replaced it
Old 01-29-2014, 10:00 AM
The engine temp sometimes fluctuated (the needle would jump), and then I ultimately got a check engine light, although it may have been from a bad coil pack since I had a cylinder 3 misfire as well. There was a slight idle fluctuation but again, it could have been the misfires. Anyways, I replaced the sensor, and coil packs and plugs and all is well (although I have a leaky valve cover gasket that needs attention next).
gmtalike
13
06-18-2015 08:24 PM
MN-A8
08-22-2013 09:17 AM
Monkeyboy
10-20-2008 02:39 PM
allroad(s) lead 2Gavin
Audi allroad
9
12-02-2007 11:50 AM
Quick Reply: How much to change a tempature sensor
