Reduce Warm up time, Increase smooth idling.
2004 Audi A4 1.8L +137k miles:
-It takes a long time to warmup
- when warming up it sits at 1500rpms for 5 min then comes down to 500rpms
-sometimes while stopped at a light it starts to vibrate slightly a little more and then goes back to smooth running.(also does this randomly while driving)
any thoughts???
any thoughts???
What is the temperature gauge doing after a cold start? It should be up to temperature within say 3 miles at moderate speed. If it takes a loooong time to come up it's probably the thermostat.
The vibration at stop lights is caused when the SAI pump kicks in. Over the years they have smoothed it out but it was still pretty new technology in 2004. I have a 2000 Passat 1.8t and it get's warm pretty quickly when driving it. However if I just let it idle it takes forever to warm up.
That just how the SAI pump works. Replacing it won't change anything unless something is wrong with the system. However doing a coolant flush and fill with new coolant and also replacing your thermostat might help. Bleeding the air out of the system is a pain in the ***. I highly recommend a vacuum coolant fill tool. Makes a pain in the *** job easy.
https://www.ecstuning.com/Search/Sit...ill/ES2712734/
Is the supply air pipe from the SAI still attached?
On my Allroad the plastic pipe from the pump fell off. (its at the back of the engine on the 2.7T so not obvious and it does not have a clamp).
Real 'loudness'! sound and of course extended running as it was effectively pumping air into the engine bay, so check the hose is still attached.
JeffAhn
11
09-23-2008 12:51 PM
