235/40-18" Tires vs. 235/35-19" Tires: Advantages/Disadvantages of 19" Tires?
Old 02-11-2004, 01:47 PM
Junior Member
SP (oenophile)'s Avatar
Default 235/40-18" Tires vs. 235/35-19" Tires: Advantages/Disadvantages of 19" Tires?
Granted they are same tires just bigger size (i.e. Michelin Pilot Sport PS2) Is Bigger always better? Better handling, cornering, and etc? What are advantages and disadvantages of the bigger tires?
TIA,
Sol
Old 02-11-2004, 01:52 PM
DolphinV8's Avatar
bend, cost, handling, and blah blah..
Old 02-11-2004, 01:53 PM
Tsle's Avatar
Default Cost is the biggest disadvantage, but also you don't really gain much/anything from 19" vs. 18" (m)
In terms of handling. On an 18" wheel, the tire sidewall is already as short as necessary to for optimum stiffness. Bigger is not always better. I would recommend 18" if you can cough up the dough for 18" tires, but most of the time, 17" is acceptable and 19" is just not helpful.
Old 02-11-2004, 01:56 PM
obLu's Avatar
Default Purely cosmetic. Lots of disadvantages.
But they look oh so sweet.
Old 02-11-2004, 01:58 PM
AudiWorld Expert
ex-quattro PETE's Avatar
Default Only advantage is looks
unless you have big *** brakes that won't fit over 18" rims, then you have no choice.
Disadvantages: cost of rims and tires, poorer acceleration, braking, handling due to higher unsprung weight; higher risk of rim damage; harsher ride.
Old 02-11-2004, 02:02 PM
Elder Member
oatzel's Avatar
those would be some big *** brakes considering the rs6 brakes fit under 18's
Old 02-11-2004, 02:07 PM
Member
Chris not @ Toyo now's Avatar
Default See the attached link for the post below. Looks is only advantage
<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/521541.phtml">https://forums.audiworld.com/a4gen2/msgs/521541.phtml</a</li></ul>
Old 02-11-2004, 02:10 PM
AudiWorld Expert
Old 02-11-2004, 02:18 PM
New Member
Audination's Avatar
Default Re: 235/40-18" Tires vs. 235/35-19" Tires: Advantages/Disadvantages of 19" Tires?
If your thinking of running 19's. You may want to consider going to 245x35x19. It will protect your wheel a little more from potholes and bad roads.
The 19's look better but they're louder and more susceptible to damage. I'm selling mine. I already pickuped some 18's.
Old 02-11-2004, 02:30 PM
ILMA_Revo_Stage_2+'s Avatar
Default 19s have a harsher ride
also bend easy I think, you gotta watch how and where you drive. i've given up on 19s, i am picking up some 18s soon.
Quick Reply: 235/40-18" Tires vs. 235/35-19" Tires: Advantages/Disadvantages of 19" Tires?
