Transmission leak?
Transmission leak?
Hello. Yesterday I went to the garage to get my resonator exhaust repaired. I noticed as I walked under the car, that a bit of transmission fluid were at the differential level, but just a bit that I can take off with my finger. The mechanic told me not to worry, that it was normal to have a minimum flow of transmission fluid. Is it true?
My 2 cents:
Not sure I would call it "normal", but it is not harmful. I am very tolerant of these sort of seeping leaks even if it is enough to fall to the ground. There is obviously a point where it may get big enough to need attention and you need to monitor the fluid level.
rimA6
08-31-2011 12:02 PM
AlexRM
12-22-2004 09:56 AM
coocoomike
06-22-2002 08:22 AM
