Used ECU and instrument cluster replacement
Old 05-26-2015, 11:03 PM
DeividasJ's Avatar
Default Used ECU and instrument cluster replacement
Hi!
Car does not have its original ECU and Instrument cluster, both are replacements from other cars (I have new instrument cluster PIN code). and the only way to drive a car at the moment, is with disabled immobilaizer. We have tried various adaptations and other stuff with VAG-COM, but no luck at all. I think the main problem is that both components was replaced at the same time, so none of them does not contain original immo info (or smth like that). While doing adaptation, at some point I'm always getting "SYSTEM NOT OK"
So, my question is: is there any chance to adapt new components to my car, that immo can work again at home or the official dealer is the only way to go?
I've got a suggestion that I need to directly rewrite the immo on both the ECU and cluster, at the EEPROM level. But it is a bit confusing, since I have only ECU replacement, what immo should be rewrited? From where?
Can these immo problems cause "communication errors" on other components?
01317 - Control Module in Instrument Cluster (J285)
49-00 - No Communications
01330 - Central Control Module for Central Convenience (J393)
00466 - Control Module for Steering Column Electronics (J527)
00457 - Control Module for Network (J519)
00474 - Control Module for Immobilizer
01320 - Control Module for Climatronic (J255)
Or these problems are not related and I have to solve this in other way?
1.9TDI 96kw.
Thanks.
eunos_rsh
VAG-COM Discussion
08-20-2007 11:02 AM
AMDS4
05-30-2006 07:07 AM
alex007
VAG-COM Discussion
05-24-2003 12:02 PM
hlTT
02-22-2001 05:28 AM
Quick Reply: Used ECU and instrument cluster replacement
