Fan kicks on more than it used to and runs longer too?
Old 12-08-2006, 04:07 PM
EBG 18T [Eric]'s Avatar
Default Fan kicks on more than it used to and runs longer too?
what would cause the fan to kick on more often and run longer when i just start the car. It just started happening about 2 weeks ago. Any ideas?
Old 12-08-2006, 04:16 PM
gimik's Avatar
Default thermostat or engine coolant temperature sensor..
in my case my thermostat was stuck open (82k miles).
my fan would kick on even when the car was trying to warm up, and would not get to the standard operating temp unless i had been driving for a good 15 min or so (as opposed to the normal 2-5 min warm up).
i replaced it with the help of a friend.. unfortunately it's like $200 assembly, but the DIY job isn't crazy.
Old 12-08-2006, 04:24 PM
Default is there a way to tell whether it is the thermostat or the coolant temp sensor?
i just don't want to replace 1 and have it be the other.
Old 12-08-2006, 09:08 PM
psuaudi's Avatar
Default the cooling fan shouldn't come on when the engine is cold. to me, that points to the ECT
there's a writeup on how to fix it in the tech articles. it's a cheap fix...just a little bit of a PITA.
when mine was bad, i would start the car, and with a cold engine, the cooling fans would kick into super-turbo-speed. after replacing it, all is well.
Old 12-09-2006, 05:10 AM
thanks. i will so a search on that and dig it up.
Old 12-09-2006, 10:09 AM
gimik's Avatar
Default the engine coolant temp sensor is a pretty cheap and easy fix.
i did that first since it's like an $8 part and a 20 min DIY. unfortunately for me that didn't fix it, and the thermostat was the real issue.
N'Syncro
33
02-16-2020 03:12 PM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
texasaggie2011
09-14-2015 05:39 AM
raiderrider
12
09-08-2015 05:46 AM
Quick Reply: Fan kicks on more than it used to and runs longer too?
