what can cause a noisy fuel pump?
02 A4 1.8t, very noisy fuel pump, not really a loud hum, more like a pulsating vibration type hum, the tone changes every now and then and drives me nuts, i changed the fuel pump and the new one does it as well, changed the filter and it still makes noise, although it stoped for a few minutes with the filter change. it started this a few months ago on and off and then it quit, but it would make noise every now and then, now it's been making noise for the past week and a half all the time. I haven't checked voltage to the pump but that was my next step,it just sounds like the pump is struggling but the car runs great
If you ever figure this out let us know please. My car has had the dreaded humming/buzzing sound of the fuel pump for years. On my car though it seems to only happen when the fuel is super low (around 40 to 50 miles left in the tank). I have learned to just refuel at about 75 miles left. Gas seems to muffle the sound...ive tried multiple fuel pumps and fuel filters with no success. Car still runs great though, so cant complain
yea thats how mine started, over time it made more noise more often, and now even with a full tank it is noisy. makes no difference empty or full. but some days it makes no noise at all. other days people outside the car ask me what is that noise!!
I am curious because I am having a similar issue and after I replaced the fuel filter it's still buzzing. This is my second fuel pump, the first one was replaced under warranty due to the recall.
theres a service bulletin about this. The filter clogs and causes the pump to strain and be noisey, replacing the filter may solve it, if it doesnt, replace the pump. if your still having issues, make sure the pump was locked into its sort of slot inside the tank and isnt vibrating, make sure all the fuel lines are in there proper retaining clips, make sure no lines have been partially crushed by a lift or something. other than that, bad quality pumps
This fuel pump was replaced by Audi dealership under the recall warranty. My previous pump just all of a sudden died one day while I was waiting at drive-through, with zero warnings.
How urgent do you think I should replace the fuel pump? I guess it won't hurt to always have a stand-by in hand?
Cheers,
Noisy fuel pump
I had a similar issue on my 04 1.8 a4. I just replaced the engine position sensor bcs it was causing my car to die a lot. And after replacing it and doing nothing else my fuel pump is no longer noisy. Not sure if related or coincidence though.
anarchyjet
09-08-2006 09:33 AM
