Wipers won't stop cycling!!!!!!! - AudiWorld Forums
LinkBack Thread Tools Search this Thread
Old 08-12-2014, 01:58 PM   #1
Default Wipers won't stop cycling!!!!!!!
I have an 04 B6 quattro and during the last rain storm my wipers would not stop cycling. With the wiper switch in the off position, the wiper continue to cycle. I replaced the wiper motor with no luck. Purchased a wiper swith and I think I bought the wrong one. With the replacement switch mounted the wipers still cycle and no directionals, or headlights. re-installed the original wiper switch lights and directional work, but the wipers still cycle and the wiper fluid wouldn't dispense.
I removed the fuse a way t control the wipers.. When the OEM switch was removed the following numbers were on the side....
4E9 953 503B - I'm assuming this is the part ?
CZ KL0 01 2046 02 - Whats is this number ?
06.12.03.09- What is this number ?
Is the wiper switch still the cause? What else should I look for?
Thanks in advance
Mark
woodysb6 is offline   Reply With Quote
Old 08-13-2014, 12:52 PM   #2
I'm suprised that out of 59 views no one has any input.
Old 08-14-2014, 07:39 AM   #3
I started to respond but didn't because I didn't know where to point you.
When I read "after a heavy rain, my _________ wouldn't turn off / work", I immediately think water intrusion on a relay shorting it out. But, I have no idea where the relay for the wipers is.
lyleswk is offline   Reply With Quote
Old 08-14-2014, 12:21 PM   #4
Prospeeder's Avatar
Im going to say the wiper relay has stuck and keeps powering the wipers. I think its in the relay panel under the driver kick panel ill have to look.
Prospeeder is offline   Reply With Quote
Old 08-16-2014, 08:01 AM   #5
Update:: Replaced the wiper switch stock, no change. Replaced the relay, no change, replaced the wiper motor, no change.
I have no choice but to make an appoinment and get my a$$ handed to me over this ever so frustrating issue. Make's me wonder what else will go wrong.
Old 08-19-2014, 11:56 PM   #6
Hi. The wipers are powered by a component called the Onboard Power Supply Control Unit. It powers the lights, wipers, horn and other circuits.
It is located up under the drivers side under dash trim panel and is a square and flat in shape Given it's location it is possible water ingress may have caused ifs failure, however not necessarily as they do occasionally go wrong.
I used to work as an Audi Tech so have a bit of experience with these. Hope this helps.
gsjohal is offline   Reply With Quote
Old 08-26-2014, 02:57 AM   #7
Default wipers
Thanks for the information. Do you know of a website that I could locate the part number?
Thanks
Mark
Old 09-09-2014, 04:32 PM   #8
Many thanks to gsjohal for suggesting theOnborad Power Supply Control Unit...that fixed the continous cycling. One issue that has occured is the wipes don't return to the start point. They end about 25% above the start point. Can a VAG connection adjust the timing? When the car is off I can manually return the wipers to the start position.
Many thanks gsjohal!
regards,
Mark
Old 09-09-2014, 04:38 PM   #9
The part number for the Onboard Power Supply Control Unit for my B6 is 8E0907279F.
I purchased the part from Wolf Auto Parts.
Old 09-10-2014, 05:28 AM   #10
What determines the timing of the wiper blades. Is it the Onboard Power Supply Control Unit or the colunm switch? After replacing the OPSCU and starting up the car the wipers jumped to 25% above the bottom of the windshield. When I set the column switch to continious the wipers cycle correctly, top to bottom. When there set to intermitten the stop 25% above the bottom of the windshield. When I shut the wioers off the the wipers end at the 25% point. With the column switch off, I can manually move them to tbe bottom of the widshield.
Any suggestions?
Thanks,
Mark
Thread Thread Starter Forum Replies Last Post
convertible top rear latch wont manually open bigemike A4 Cabriolet (B6 Platform) Discussion 1 12-02-2016 10:31 AM
Moody Turbo must be time of the month ;) Aman Singh Parhar A8 / S8 (D3 Platform) Discussion 7 11-29-2016 06:03 AM
Wiper/washer operation? JuliusK Q5/SQ5 MKI (8R) Discussion 7 09-24-2015 05:54 PM
Rain sensing wipers fuzzydice A6 (C7 Platform) Discussion 15 09-18-2015 02:11 AM
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
What's your question?
Send
