A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
What is the longest length bolt we can use w/o damaging hub?
Old 09-29-2009, 02:36 PM
AudisticS5's Avatar
Default What is the longest length bolt we can use w/o damaging hub?
Assuming that my stock wheel bolt is 28mm (B8 S5), would a 34mm bolt be safe to use and not damage the internals of the hub? This is for the front axle only... so no E-brake.
I know this may belong in a B8 forum, but there's higher volume of people here, and I'm assuming their hub builds haven't really changed.
Much thanks in advance.
Old 09-29-2009, 02:51 PM
Former Vendor
MikekiM@PureMS's Avatar
It's not that you'll damage the hub, but the bolt will hit the upright, which is just behind the hub. Keep tightening after it hits that, and you can potentially cause other damages.
There's typically a 1-2mm tolerance in length behind the hub. 34mm will almost certainly be too long.
Old 09-29-2009, 06:01 PM
AudisticS5's Avatar
I see... Thanks for the info Mike.
Old 10-06-2009, 02:58 AM
shawfm's Avatar
What about going to wheel studs. That way you could get longer, and Mike can sell them to you.
http://www.purems.com/products/product.php/II=2796
riotburn
04-20-2009 11:25 AM
e40
02-10-2008 04:29 PM
BiturboBoy_V2.0_S3--
08-21-2004 08:09 PM
chw6922
02-06-2004 03:22 PM
Pete Deckman
Misc. Models Discussion
09-06-2000 08:32 AM
Quick Reply: What is the longest length bolt we can use w/o damaging hub?
