2007 A4 2.0T - fuel pressure code
Code 012555 low pressure fuel regulation
is coming back.
Is that indicative of the common fuel pump cam follower wear/failure?
Thursday,06,November,2014,10:36:46:36008
VCDS Version: Release 12.12.3 (x64)
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 8E0 910 115 P HW: 8P0 907 115
Component and/or Version: 2.0l R4/4V TFSI 0020
Software Coding: 0104010A190F0120
Work Shop Code: WSC 00191 264 15243
VCID: 2E53B629B99BED6E391-807B
1 Fault Found:
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 234719 km
Time Indication: 0
Freeze Frame:
RPM: 778 /min
Load: 29.0 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.208 V
Readiness: 0000 0000
is coming back.
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 234719 km
Time Indication: 0
Freeze Frame:
RPM: 778 /min
Load: 29.0 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Voltage: 13.208 V
Only changed the cam follower.
Code comes back once in a while.
Hope it holds up until car can be shoved into an Audi dealers rear end as trade in (erase code when pulling into the lot, naturally).
Audi declined any support due to 150k miles.
Note: car has been at Audi dealer several times (among other things: installed new fuel pump, installed new thermostat, etc) while under warranty, but they did not mention or check or follow the TSB that Audi issued for the car.
This is VERY tyipcal. Photos in Audi TSB look the same.
Car runs fine, but code comes back once in a while. Pretty sure the cam and the HPFP have worn.
Audi TSB here fyi:
https://www.dropbox.com/s/s7titzum7s..._wear.pdf?dl=0
Audi TSB here fyi:
JiBBeL
15
04-13-2018 08:26 AM
smashtheqube
RS4 (B7 Platform) Discussion
07-17-2007 04:31 PM
