2007 A4 Quattro S-Line 3.2L V6
I started hearing a bunch of grinding in the engine compartment during travel and at stops. Eventually, it started becoming worse on startup, and then never stopped. Finally, I took it in for an oil change and discovered it was my A/C Compressor fixing to end it's life. Yesterday, when I got back home it ended, that was it, I discovered the A/C clutch pulley fixing to break off because it was grinding and moving from side to side way to much so now its parked and needs fixing. The dealer blew me away with there cost, so I want to try and tackle this project on my own.
1. I seem to be confused on the model, am I correct by stating that my 2007 Audi A4 Quattro S-Line 3.2 L V6 Wagon...is it an :Avant"? or just "Wagon" and, what motor B7?
2. I'm evenly mechanically inclined, but not so much on this vehicle. Do I have to remove some of the front end to get to the compressor?
3. Do I need to replace other components as well during this new installation and what are the components?
4. What exact replacement compressor do I need to buy?
5. Do I need to discharge the system before disconnecting compressor?
6. What tools do I need to get the job done?
If someone has already performed this type of DIY project, can you or, will you elaborate for me? And if so, can you call me personally at 321-456-6472 or, if you are in the Palm Bay, FL area lets touch base, I'm willing to pay for quality help?
Thanks,
Roy
Thanks,
Roy
Aldrich67
05-03-2015 10:10 PM
XJUSTXINX
08-02-2007 09:35 AM
albertolima
09-24-2001 08:05 AM
