A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Old 08-09-2016, 12:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B7) Specifications & General Maintenance
Print Wikipost
ElsaWin Service Manual
Old 04-24-2009, 05:46 PM
clemsongt's Avatar
Default ElsaWin Service Manual
There is a service manual called ElsaWin. "ELSAWIN is the Service & Repair Workshop software actually used by the Volkswagen, Audi, Seat and Skoda main dealers and factory technicians around the world, it covers cars (with varying amount of informations) from 1947 till today. It provides Servicing Guides, Workshop - Repair Manuals, Electric Schemes - Wiring Diagrams, Body Works." It can be downloaded and installed giving us a huge amount of information.
There are several places to download it. It can be found on many different torrent sites:
http://www.torrentreactor.net/torren...NGUAGE-ISO-TBE
http://thepiratebay.org/torrent/4702...P_VMware_Image
http://isohunt.com/download/62582497/elsawin.torrent
If you aren't into torrents, then you can download each individual file from the links below (much more tedious of a process). The files are fairly prevalent around the internet, so if any of these links don't work a simple google search might help.
CD1 (install):
http://netfolder.in/folder.php?folder_id=nTa1C91
DVD1 (Audi):
http://netfolder.in/folder.php?folder_id=kETL1YR
DVD2 (Seat):
http://netfolder.in/folder.php?folder_id=N5BsL2K
DVD3 (Skoda):
http://netfolder.in/folder.php?folder_id=PTUjJ4F
DVD4 (VW Disc 1):
http://netfolder.in/folder.php?folder_id=Wieo5VN
DVD5 (VW Disc 2):
http://netfolder.in/folder.php?folder_id=l7s92Q6
Once all of the files are downloaded (only need the install CD and DVD1 for Audi), the install process can be completed.
1) If you don't have WinRAR, you will need to download it. All of the files are compressed in a .rar file. WinRAR is a file extractor like WinZip.
2) If you don't have a disk image emulator download one, both PowerISO or Daemon Tools should do (all three install links are from download.com). All pictures will be using PowerISO.
3) Now that both WinRAR and an emulator software are installed, you can begin the install process. Open the folder that you have saved the files, right click on the file welsa36in.r00 and "Extract Here". Now do this same extraction with welsa36au.rar.
4) While the second set of files are being extracted, you can begin installing the CD. Right click on the first file that you extracted (welsa36in.bin) and "Open with" your emulator program. Find the file labeled setup.exe, and double click.
5) CD Install:
Click 'OK' to extract all files to a temporary folder. Once that is follow the install instructions. At the second step you will need to input a serial number. This can be found in the 'install.txt' file in the 'crack' directory.
Once the number is pasted into the cell you will be asked if that is correct...it is. Now you will need to choose some options. I do not know what exactly they mean but the combination shown of:
"Repair Operations List + Service Package Quotation System + Editing system" and "Apos" does work. Now finish the install by choosing where you want things installed.
6) DVD Install:
At the end of the CD Install, you were told that the data cd must be installed. That will happen next. By now, the second extraction that you did should be complete. You should now open the extracted file, welsa36au.iso with your emulator software. Once it is open you should run 'setup.exe'. Once this file is extracted and installed, your program should be ready to run.
7) Program operation:
When you open the file "ElsaWin", it will ask you to login. admin/admin should do. You can also create multiple logins if you want using the "ElsaWin Administration" file. Hit "OK" on the Note that pops up. Even though you installed the file with the English settings it will still be in German. By clicking the fourth menu option and then the second in the list you can change your settings (I've already changed mine to English...).
8) The rest of the program should be pretty straight forward, but if you need some more help watch this video.
Any comments or suggestions just let me know.
Old 05-02-2015, 05:11 PM
mkellysc's Avatar
Default ELSAwin
Do you still have the direct downloads? I can't pull it off of any torrent sites. I could really use this. My 2007 Q7 is giving me all sorts of issues.
Old 05-10-2015, 08:45 AM
mc_hotmail's Avatar
You need to be patient and use torrent. It took me couple days a few years ago. Once you got your copy, leave the torrent online to give back to the community. ElsaWin 3.6 covers 2009 or older models, which includes both versions of 2.0T and the 3.2 V6. ElsaWin 4.x has newer models.
Old 05-10-2015, 09:01 AM
spijun's Avatar
Version 4.xxx to old
ELSAWIN 5.2 is for newer models
VER. ----- AUDI ------SEAT------- Volkswagen------Skoda
5.2------- 1.2015-----1.2014------ VW 1.2015
----------(22,2 GB)------------------(32,9 GB)
In total, about 68GB for all brands
Old 06-24-2020, 09:38 PM
antichiter's Avatar
Default elsa-online
Hello. I create elsa-online
https://www.kolhosniki.ru/elsaonline
kalmifl (11-12-2021)
Old 03-06-2021, 04:41 AM
rowdyaudi2's Avatar
I can't download anything from those links.
What am I doing wrong?
Old 03-26-2021, 12:42 PM
Space.Pyrate's Avatar
Anyone have an updated log/file None of these work.
Gas Hed
Q5/SQ5 MKII Discussion
06-01-2017 04:20 PM
GeoffPFC
Q7 MK 1 Discussion
04-09-2012 12:02 PM
Mudd93
02-22-2006 09:57 AM
SmokinS4™
10-31-2002 08:07 AM
PeteW
05-24-2002 12:09 PM
Quick Reply: ElsaWin Service Manual
