Last edit by: IB Advertising
- Audi A4 B7 How to Locate EVAP Purge N80 Valve<br>Step by step instructions for do-it-yourself repairs.
Can't fix CEL P2404
Can't fix CEL P2404
About 2 months after I bought my car I got a P2404 CEL. Did some research and google fu and found most people suggest replacing the N80 Valve. Did that and CEL is still there. Took the car to a local Audi only shop, they did a smoke test, tested the sensors and everything was within range and no leaks detected. Some more googleing has found that a few people have gone all the way to replace the ECU to fix this issue. My smog is due at the end of the month and I'm running out of time to fix this. Has anyone actually fixed the P2404 error and was is the ECU or is there something else to try before I go that route? And if I do how hard is it to replace the ECU? Do I need to take it to Audi or is it simply plug and play?
Thanks,
Ron
Thanks,
Ron
I'm still trying to fix too. I've ignored it until it had to be smogged. Replaced the stupid LDP twice. Did the smoke test. That wasn't it. Luckily I only paid 350. I have no clue. I think I may say F the smog test.
Thanks,
Ron
Thanks,
Ron
The Audi mechanic explained it like this. The ECU has a bad ground, but it won't trigger a CEL. The Bad ground stops the Evap Pump from working, which in turn stops the Evap Pump Solenoid from going. But since these are only used on start up, on cold mornings, or during certain times the error may not show up till the pump burns out, after the pump burns out the pump solenoid will go bad, then trigger the p2404. If you replace the Evap Pump but it still doesn't turn on in the ECU is bad. So in turn you'll need to replace the ECU. I replaced mine and the lights been gone. I check it daily with my OBD II logger and no codes are pending or showing.
Hope this helps.
Ron
Hope this helps.
Ron
P2404 issue fixed
Thanks,
Ron
Thanks,
Ron
