Car "hiccuping" on heavy acceleration
#11
Thanks! My car still does this. It needs a number of things done so I'll be asking the mechanic about this when I take it in. It sure is frustrating!
I have a 2009 A4 that exhibited the exact same problem, almost like a cough during hard acceleration under load.
Took it to the dealer, and he said that 3 of my 4 ignition coils were on their last legs and that I should replace them asap or I could be left stranded.
That's scheduled in 2 weeks and will report back on results.
Rochelle13 (10-18-2021)
#13
Thanks for for the feedback! I took my car in today and they have many things to do. Once they call me I'll ask about the ignition coils.
#14
Problem solved(finally!)
It turns out that I could've simply went to the new mechanic I go to now a long time ago and the problem would've been solved! He recommended a number of things be done, but he figured out the problem after seeing my car once (I just hadn't taken it back in because life in general). Turned out he called it when he said the fuel pump was weak. He replaced that, and now my car is totally back to normal! I thought I would have to deal with that problem for however long I decided to keep this car. Totally appreciate the feedback and help I received here. Thanks all!
#15
I see you had success with ignition coils. I wondered if my symptoms sound like what you experienced? Any help is welcomed. I'm due at mechanics this week and don't want wild goose chase that costs a fortune
Thanks
#16
Hi, I'm new here. My 2010 2.0ltr turbo audi a4 has started doing this. Was driving along at 100km and suddenly started juddering and choking. If I drive around at low speeds, gently and change through gears slowly with little acceleration it doesn't do it. Any higher revs or acceleration and trying to go a faster speed in general and it starts again. The juddering gets really bad, causing it to rough idle/and cel/epc warning lights come on and seems to be running on less cylinders.
Thanks
Thanks
#17
I recently replaced a brand new set of Ignition Coils on my '08 2.0T (genuine Audi part 07K-905-715-G) and I can definitely feel my car running smoother than before. I have 92,000 miles and for the most part had no issues but decided to replace the coils as a preventive maintenance. I can immediately feel the quicker response from a standstill and it boosts way better than before minus the occasional hiccup/hesitations. My main objective for replacing the coils is hoping to get better gas mileage, which they do seem to rob when aged or starting to go bad. Nevertheless I'm extremely happy.
#18
guy and all, I had the same issue. Replaced "F" version coils (Black-tops) with Audi Genuine R8 coils. Red tops. That was six+ years ago and no issue to date. And yes that $ was for all four. I got a deal on them at the time via Amazon Warehouse Deals. Haya....
October 2016
“F” version kept as spares (4)
Amazon WHD-Heritage VW $68
Genuine Audi OE “E” version R8 ignition coils (4) part no. 06E905115E
October 2016
#19
#20
Hey, so my car has begun to have this happen first thing I did was order 4 brand new ignition coils. And I’m waiting to install them. Before I do that. Have you done anything with the vacuum pump. I got my car back from the shop today and had the vac pump replaced now my car is doing this. Thanks so much.
