Check Engine Light - AudiWorld Forums
A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Check Engine Light
Old 07-16-2014, 10:47 PM   #1
Default Check Engine Light
This is my first post on here about my car. I have a 2007 Audi A4 and it has 102,500 miles and my check engine light came on 4 weeks ago. The OBD showed it being the fuel pressure sensor at first so I got it fixed. The light came on again and this time the OBD showed the fuel pressure regulator being the issue so I got it fixed along with the fuel filter. I also replaced the spark plugs. The light came on again, but I am out of ideas and so is my mechanic. Please help if anyone has any good recommendations.
Allen Pepple is offline   Reply With Quote
Old 07-16-2014, 10:51 PM   #2
Correction on my post....I had it put on the OBD2 system to receive the proper diagnostic.
Old 07-17-2014, 09:57 PM   #3
Quote:
Originally Posted by xcar360 View Post
Which scanner did you use?VAGCOM?
I went to Advance Auto Parts and the guy used the Actron OBD 2 Scanner.
Old 07-17-2014, 10:09 PM   #4
XCAR360:
Just found a website, which shows that it could be the oxygen sensor, loose or faulty gas cap, catalytic converter, mass airflow sensor, and spark plugs with wires. Well, I changed the plugs, but didn't change the wires. If any of these listed above, wouldn't it have set off the OBD Scanner to give me a code?
Old 07-30-2014, 12:26 PM   #5
Chief Cook and Bottle Washer
Kris Hansen's Avatar
You need to get a proper scanner, like a VAG COM on that car, and find out the exact codes it is throwing.
Kris Hansen is offline   Reply With Quote
Old 08-01-2014, 10:34 AM   #6
Seems like this thread is missing a few replies?
When you had auto zone scan they should've given you some codes. Did you happen to get them?
By wires, on your car, it means the ignition coils aka coil packs.
What exactly are any symptoms of you starting, idle, driving characteristics right now?
Dolamite is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
:: ECS Tuning :: NEW!! B8 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B8 Platform) Discussion 14 12-23-2016 04:46 AM
Why I hate NJ's numbnuts rules... carl viking A8 / S8 (D3 Platform) Discussion 34 08-22-2016 08:44 PM
Got an A7, wanna ask some questions :) zhaoweitian A7 2 09-01-2015 04:15 PM
:: ECS Tuning :: NEW!! B7 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-01-2015 10:16 AM
:: ECS Tuning :: NEW!! B8 A5 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-01-2015 09:27 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
