Cold start / rough idle / misfire on 1, 2, and 3
I've got a 2005 A4 that has a rough idle on cold start. When we clear the codes by disconnecting the battery the car starts fine and drives fine but then the next morning it starts rough again. The car is giving the following codes:
16684 - Random / Multiple Cylinder misfire detected PO300 - 001 0- Intermittent
16686 Cylinder 2 PO302-001 - Misfire detected Intermittent
16687 Cylinder 3 PO303-008 - Misfire detected intermittent
16685 Cylinder 1 PO301- 008 - Misfire detected intermittent
18010 - Power supply terminal 30 P1602 -002 Voltage too low - intermittent
I've been dealing with this for weeks and have changed all the spark plugs, coil packs, throttle body, air filter.
Any ideas would be greatly appreciated.
it's gotten worse
Head Gasket
Sounds like a head gasket.
Missing coolant and misfire almost guarantees it. The coolant usually doesnt go in the oil it goes in the cylinder and burns out the exhaust as steam.
mmdambro
04-11-2011 06:05 PM
Matt Devo
04-19-2007 11:13 AM
PSmalls::DoggieStyle
17
10-18-2005 04:34 PM
In an attempt to reduce cold start misfires, I reduced start up and warm up enrichment to 83.6%.....
13
10-17-2005 02:15 PM
