:: ECS Tuning :: NEW!! ECS 2-Piece Direct-Fit Brake Rotors | Audi B7 A4
Audiworld Basic Sponsor
Light on weight. Long on looks. The new ECS Tuning 2-Piece front brake rotors combine the natural advantages of a cast iron braking surface with the weight savings and rapid heat dissipation of an aluminum hat.
Cast iron-gray and durable matte black hats create an eye-catching contrast that accents painted calipers behind open-faced alloy wheels.
These beauties have all the extras: black anodized hats, cross-drilled and slotted brake faces, and unlike OEM, directionally vaned rotors for better cooling and heat dissipation over stock.
Features include:
- Aluminum hats: To save weight, each rotor ring is bolted to a lightweight aluminum hat made from high quality 6061 aluminum, and hard anodized with an attractive matte black finish that is both durable and corrosion resistant.
- Gray cast iron rings: Long known for its wear resistance and stable friction characteristics, cast iron is favored for brake rotors due to its ability to absorb and dissipate large amounts of heat.
- 2-Piece construction: Conventional rotors are unable to cope with the stress of drastic heat fluctuations and are prone to warping. ECS 2-Piece semi-floating rotors allow the radial expansion of the rotor ring - preventing warping.
- Heat treated: Heat treating further reduces the tendency for rotor cracking by reducing internal rotor stresses.
- Directionally veined: ECS 2-Piece rotors feature directionally curved veins, directional veins accelerate air away from the rotor at a higher velocity, leading to consistent, rapid cooling on both sides equally.
- Drilled and slotted: 2-Piece rotors are cross drilled to promote cross ventilation for improved cooling as well as slotted to clean brake pads and carry away water and brake dust. Cleaner brake pads result in faster, more consistent stopping. Drilled holes are chamfered while slots are machined with a ball end mill - both to prevent cracking that may be present on improperly machined rotors.
- Overall weight savings: This particular ECS 2-Piece rotor weighs only 17.2 lb compared to a stock rotor (22.7 lb). Lighter rotors reduce unsprung weight and rotational mass to improve both braking and suspension performance.
- Includes ECS Stainless Rotor Set Screws to eliminate rusty factory fasteners
Stop with Confidence
Click HERE to order or for more information
Fits:
Audi B7 A4 2.0T (2005.5-2008)
Let me know if you have any questions.
Jason
ECS Tuning-Audi
Audi A3 / S3 / RS 3 MKII
07-27-2017 09:52 AM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
05-30-2016 12:33 PM
ECS Tuning-Audi
05-19-2016 12:49 PM
ECS Tuning-Audi
Audi A3 / S3 / RS 3
03-30-2016 09:39 AM
ECS Tuning-Audi
01-08-2016 08:26 AM
