A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
engine coolant temperature sensor circuit high
Old 08-28-2016, 04:44 AM
grahamjf's Avatar
Default engine coolant temperature sensor circuit high
Hi all
Took my Audi A4 2.0TDI 2005 in to Audi to get a diagnostic check done and it came back with P0118 engine coolant temperature sensor 1 circuit high.
I have changed the ect sensor with a genuine audi one before it went in to get scanned, The temperature gauge dos'nt move off the cold unless the car is booted going up hill, dosnt even reach the first notch even on a really hot day, When it does move, after you stop booting it up hill it drops back to cold again.
The thermostat was changed as well 88degree
What does high circuit mean?
Any ideas on what wrong?
Did read about trying this but not sure if this could cause further damage or not
unplug the sensor and, using a fused jumper wire, jumper the two terminals of the connector together. The temperature reading should now be maxed out
Read more at: OBD-II Trouble Code: P0118 Engine Coolant Temperature Circuit High Input
Copyright OBD-Codes.com
Willgatlin25
Q7 MK 1 Discussion
06-20-2019 04:38 AM
Jniebles
11-01-2012 06:28 AM
ufk22
03-03-2011 07:18 AM
absentme
10-10-2002 07:05 PM
reza
11-28-2001 08:39 PM
Quick Reply: engine coolant temperature sensor circuit high
