A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Hissing noise from brake pedal?
Old 05-01-2012, 11:00 AM
blisteringft's Avatar
Default Hissing noise from brake pedal?
2006 A4 2.0tq auto. I've noticed lately that there seems to be a noise coming from the brake pedal, when I'm NOT stepping on the brakes. It's enough that I can hear it when driving around at less than highway speeds.
It sounds like a hissing noise. If I press the brake pedal down a bit, it stops then slowly comes back. If I press the pedal down more (full stop) the noise goes away until I let off the pedal.
Anyone heard of this? Know what it is? Recall (please be a recall).
Thanks in advance.
Old 05-09-2012, 10:11 AM
Default Updated
Welp, I know we're all really interested in this, so here's an update.
Did some research (youtube) and found some steps to take to see if there is a vacuum leak in the brake booster or somewhere between it and the brake pedal.
Ran the car for a bit, pulled into the garage. Put it in park, foot off the brake, turn car off. Hissing noise tapered down for about 5 seconds to nothing. Wait 2 minutes, then test.
The test is to press the pedal down with the car off for 2 or more minutes. If there is a leak, the vacuum will have leaked and you'll feel little to no assist pushing the pedal. If the vacuum is good, you'll get 2 assisted pedal pushes.
I got 2 pushes no problem, even got some assistance on the 3rd push. So it seems there's not really a leak there.
Any thoughts as to what can make a hissing noise down there that stops when pushing the brake pedal in? I actually stuck my head down there while it was running and it seem like the noise is coming from behind/within that little rubber plunger. What is that?
flogsta
Q5/SQ5 MKI (8R) Discussion
48
01-27-2024 03:18 PM
Sachin Shah
Q5/SQ5 MKII Discussion
11-30-2023 04:41 PM
HVerkoff
RS 7
06-17-2014 01:47 PM
Squidbert
11-20-2006 01:25 PM
a418tq
10-08-2002 05:12 AM
Quick Reply: Hissing noise from brake pedal?
