Instructions for VAG Can 4.5 and 5.1
#11
Just an update on this.
I purchased a new LPFP and it didn't start. Fuses look good, replaced the forefront 614 relay, changed the FPCM....still nothing.
However.......
I was able to get it running by running a power wire to the LPFP straight from the battery. I also ran power to the old pump and what do you know? It powered up. The FPCM I purchased is used, and so is the relay. Maybe I need to get them both brand new? Not sure.
I'm thinking that may be the issue that I'm not getting power to the pump, or, that a rat chewed a wire somewhere.
Changed the tranny fluid, drove it, and got major hesitation at low speeds and got two tranny codes:
17106 - Transmission Output Speed Sensor (G195) P0722 - 000 - No Signal
18201 - Transmission Output Speed Sensor 2 (G196) P1793 - 000 - No Signal
TCM? Since both sensors are in that unit?
I also got a couple misfire codes. Perhaps something is up with one or more of the coils. I'll worry about that after I get the tranny fixed.
Thoughts/input/suggestions on the transmission codes are much appreciated.
However.......
mAgnum8
11-01-2008 01:01 PM
Pete5587
Chicago Discussion
07-09-2008 04:35 PM
Cypher2k
06-05-2006 07:22 PM
mbox
17
04-18-2006 06:15 AM
