P0171 DTC with intermittent rough idle and strong fuel smell
Wife's car.DTC came on yesterday.Scanned at auto parts store and got P0171.Searched the forum and found out it could be several causes.MAF,PCV,vacuum leak etc.I did notice when I was looking for leaks that the engine started to run rough and there was a strong fuel odor.I unplugged the MAF then plugged it back in a couple of times and it seemed to correct itself.Removed MAF and cleaned with electrical spray.Code is still there but the car runs fine.How many key cycles will it take for the CEL to clear? Would the fuel smell indicate a bad coil pack or a bad MAF sensor?Hoping someone can point me in the right direction.Thanks for any help.
advice Ive been given:
-get and run full vcds. generic codes are, well, too generic.
-fuel smell only at cold start or always smells ?
-google, fuel trim for audi model. trim deals with fuel/ air mixture sort and long term. some good yt videos. too much fuel could be OR too little air. either causes fuel trim issues. stuck injector for too much fuel. vacuum leak for too much air.
-do easy stuff first. check all hoses above and below, over and under, inside and out. see Scotty Limer for an easy smoke test to find air leaks.
-check for any fluids dripping under engine.
- just some starting points from a greenhorn
Thanks.Had the plastic cover off last night and did not see any obvious damage to hoses which would cause any vacuum leaks.I am leaning towards ruling out the PCV valve since it was replaced within the last 20k miles.Was hoping someone on here could narrow it down based on some of the clues I provided.
same issue
my mother has the same issues going on. did you ever figure out what it was? thanks!
also, what engine was this on? FSI? or TFSI?
branshew
06-08-2006 05:16 PM
puloo
23
09-01-2004 08:44 AM
JBear::FATS
08-31-2004 11:57 AM
PearlA4_1
12v V6 Discussion
01-24-2004 04:42 PM
vrsix
07-21-2002 06:44 PM
