P2181...help. No help from Audizine
Howdy! New member.
I have a P2181 and need to figure this out quick. I need to get smogged for registration and Im already a month late.
If I start up and get straight on the freeway, my engine will never reach operating temp. If I'm stuck in traffic, it will. For a couple weeks, it actually was functioning right and the CEL went off, but it came back. Sounds like a thermostat is stuck open, and/or the high speed fans coming on when they shouldn't. I also heard there are 2 thermostats.
Thoughts?
Thoughts?
If the engine isn't warming up, the thermostat is likely stuck open, or the spring is weak, allowing it to open early. The fans alone won't cause an engine with a properly functioning thermosat to run cool.
You don't mention which engine you have, but there is only one thermostat on all of them.
Thanks guys. I did the thermostat swap 2 weeks ago. Can't believe how they molded an entire structure around a 2 dollar thermostat, but it went by without a hitch using a DIY from Audizine
UmbroVR6
11
12-03-2015 11:44 AM
markN1689
Audi A3 / S3 / RS 3 MKII
09-12-2015 02:29 AM
kjmiles
09-04-2015 04:01 AM
