Question about Transmission Range Sensor and TCU
So I bought a used 2007 A4 Cabrio a few months back. A couple weeks ago, the CEL came on and the gear indicator panel flashes sometimes but other than that the car drives fine. I bought an ODBII reader and the code was P0706...transmission range sensor. I cleared the code then drove the car and the CEL came back on within the hour. After doing a ton of research on the interwebs, I thought I was dealing with a situation where one of two parts could be causing the problem:
I read that these parts are dealer only so I called my local Audi dealer to get prices for them. The parts guy told me that unless the vehicle is a Quattro, the TRS is incorporated into the TCU and that the TCU would have to be replaced as a whole.
I've had occurrences in the past with my motorbikes where the guys on my forums knew a lot more about the hardware than the guys at the parts counter. Not sure if that's the case here, but just wanted to get a reality check and see if the TRS and the TCU really are a single piece and therefore I need to replace the TCU (at a whopping cost of $1400).
Thanks in advance.
- TRS - which from my understanding is a part attached to the side of the transmission housing with a cable connected to it
- TCU - which from my understanding is a significantly more expensive part located under the carpet inside the vehicle
Thanks in advance.
bradwilcox
03-07-2017 06:33 AM
CHello Robinson
18
06-08-2015 09:47 AM
undertow999
12-18-2004 11:57 AM
zapco98
14
01-13-2003 09:09 PM
