Rear Parking Sensor Stopped Beeping ! Any Ideas?
I'm no Rocket Surgeon but this might be a clue -- maybe it's just the chime (?) -- how can I find the location of it and part number?
Address 76: Park Assist Labels: 8E0-919-283-8E2.LBL
Controller: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Coding: 0001314
Shop #: WSC 06325
2 Faults Found:
01543 - Parking Aid Warning Chime (H15)
009 - Open or Short to Ground
this one popped up a lot in modules -- any concern here? ->
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Coding: 0001314
Shop #: WSC 06325
2 Faults Found:
Coding: 0001314
Shop #: WSC 06325
2 Faults Found:
Coding: 0001314
Shop #: WSC 06325
2 Faults Found:
Common issue with the parktronic. The rear "buzzer" (as it is called by Audi) fails. Happened on my A6. The part itself is very cheap ($20) but getting to it requires removing a ton of stuff.
rear Park Assist "buzzer"
I am assuming there are two "chimes" or buzzers when you reverse.
Is this wrong?
powderlvr
35
04-29-2023 08:20 AM
BlackS4tt (Josh)
12
11-11-2005 04:29 AM
BlackS4tt (Josh)
VAG-COM Discussion
09-01-2005 07:33 PM
