A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
removal of XM satelite radio receiver
Old 11-17-2006, 01:48 AM
janB7's Avatar
Default removal of XM satelite radio receiver
I am transferring satelite radio receiver from one B7 Avant to another. How easy? What's involved?
Old 11-17-2006, 10:51 AM
Umlaut's Avatar
Default Easy!
Basic Steps:
Remove
1. Tuner located in rear of car, behind left panel
2. Pry open plastic drawer. Tuner is screwed to it.
3. Unplug all wires. Unscrew tuner.
Install
Reverse the "remove" procedure.
If it doesn't work for you when powered up, chances are the CAN-bus connector on the right passenger side kick-panel needs to be moved over.
that's it.
Old 11-17-2006, 02:06 PM
janB7's Avatar
Default Re: Easy!
It's out! Thanks, but it was tough getting (prying) plastic drawer out. Traded my 06 A4 2.0 Tip Avant for 07 A4 3.2 Tip Avant. After a year I decided I could not live with the vibration of the 2.0/Tip for the next three years.
Old 11-18-2006, 08:02 PM
janB7's Avatar
Default installation of XM satelite radio receiver
Couple of more questions. On the 07 besides the green and brown single pin connectors, there is a similar blue connector. There is no place for it on the receiver box plus I don't remember seeing it on the 06. There is also very little slack on the wires, to the point that I can't connect them and then slide the tray back in. Lastly, it doesn't work when I power up. Can you give me more info on "CAN-bus connector on the right passenger side kick-panel needs to be moved over" Thanks!
briburke
09-20-2011 02:00 PM
jlew
11-06-2005 01:52 PM
andye12345
07-10-2005 06:18 PM
Quick Reply: removal of XM satelite radio receiver
