Last edit by: IB Advertising
- Audi A4 B7 and B8 Door Lock Problem Diagnostics<br>Guide to diagnose trouble and recommended solutions.
2008 A4 Door Lock Problems
I have a 2008 A4 Quattro and am having some issues with two of my door locks. About 2 months ago, the drivers side rear door stopped opening from the outside. The lock mechanism was replaced and has been working fine. About a month later, the same thing happened to the driver's door but resolved on it's own. The driver's door problem is now back and doesn't seem to be going away. The only way to open the driver's door is from the inside. It does not open with the manual key either.
I'm surprised to have had the same issue with two different doors. Is this a known problem that others have had or just bad luck?
Thanks!
Thanks!
Thanks!
Thanks!
You may have a simple linkage problem if the metal key does not work. If you can hear the "thump" from the lock solenoid when using the remote in the drivers door that would almost guarantee a linkage problem.
I had the door latch on the drivers door replaced a few months ago. The lock sensor had gone bad and the car would randomly unlock/disable the alarm when it was parked. Cost me $700 out of pocket.
Yours sounds like a mechanical problem, there's clips that retain the door lock/latch cables.. could be some of those clips are fatigued/broken.
All German marques have a problem with the durability of their infrared sensor circuits. I can buy a small helicopter that uses the same remote technology as the key/door on our cars for $15.
Audi prides themselves on being an savvy engineering company. Let's see them manufacture the door handle so the electronics can be serviced without wholesale replacement of perfectly good parts.
That is a terrible price to pay for what in reality is a sensor that costs less than a dollar. Automobile manufacturers have set up a system where the dealer makes very little profit selling a car. Absent the service drive no businessman would operate a store selling only new cars. The door assembly has been marked up 30 times what it cost Volkswagen to acquire it. This is where the dealer makes a fat profit, VAG makes a fat profit, and drivers are being overcharged for the service provided.
Same as many more
I have the same problem on my 58 plate (B8) A4 Quattro 3.2 74000 Miles
At first it was the rear off side then Driver and last one, for now,
the passenger front
I have put up whit it for a while and have to agree that I have the impression that the colder it gets ...
But when the front passenger door stopped working and it would not open either from the outside or from the inside I got pretty scared
What if one has an accident ????
Never mind me but what about the most important person sitting next to me?
I shelled off £100 + Vat and changed the thing.
It seems that there are quite a few faulty locks across the AUDI range
The dude from Audi told me that they do sell a loot of them.
He shut up when I asked him why AUDI does not do anything about.
I have taken the door gigamagic apart and I think that all the problem is down to a simple spring.
I have bodged this as I have bended it a bit to much but it look better in the picture...
I will try the passenger door next (don't use that much)
A couple of question
Maybe others can try any opinion ?
What about Audi in Germany whit winters much colder any issues there ?
And last one
Why Audi does not do anything about it ?
Must say this will be my last Audi ever
the passenger front
And last one
problems of a different sort...
https://www.audiworld.com/forums/a4-.../#post25066620
Audi A4 2008
I had the same problem with the rear left door, only opened from outside then totally jammed I didnt fix it then after 6 months rear driver side started to play up followed by the driver door, could only open from inside via front passenger side door and now thats playing up too, cant get into the car, the fob works can hear thump but only the boot opens, even tried manually with key...no luck! If its a mechanical fault its weird how it effects all the doors. Crazy!!
