A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Old 08-23-2016, 10:55 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B8) Cooling System Guides
Print Wikipost
2009 A4 Radiator fan rattle
Old 05-14-2015, 03:37 PM
nobody101's Avatar
Default 2009 A4 Radiator fan rattle
Hi, I discovered today that the radiator fan on my 2009 A4 is rattling. When I turn off the ignition, I can hear it wind down and it sounds like it's hitting something. I opened the hood and the driver side one (turns out there are two!) is wobbly. I can reach down and wobble the fan on its axis. A buddy has a bit newer A4 and his doesn't wobble.
My question is, is this something that a semi-capable person could fix? Or do I need to turn to a pro? Any advice is appreciated.
Old 05-24-2015, 09:02 AM
Macallan21's Avatar
Look around. Do you see all the screw/bolt/wiring connections to remove the fan? You're going to have to take it out so that you can replace the fan bearing. It will be an involved job.
Old 06-10-2015, 06:55 PM
abarks's Avatar
The fan on my wife's 2009 A4 2.0T is failing too - fan motor squealing badly. Does anyone know where to find a write-up for replacing it? Does it have to go into service mode, bumper off, etc. or will it come out directly?
Thanks.
Old 10-06-2016, 06:54 PM
Macallan21's Avatar
Did you ever find instructions or help for this? I need to attempt the same fan replacement repair next weekend.
heloguy
Q5/SQ5 MKI (8R) Discussion
07-23-2019 01:24 PM
navidrez
08-12-2015 08:23 AM
javanator
12
05-22-2007 08:55 AM
CK:1.8T+Rabbitâ„¢
10-26-2006 01:44 PM
tobin
11-11-2005 09:46 AM
Quick Reply: 2009 A4 Radiator fan rattle
