2011 A4 Fuel Pump problem ??
Hello
2011 A4 Quattro with 55,000 miles - it has stalled at idle with no check engine or any lights. It starts back up few minutes after - maybe the High Pressure Fuel Pump fails. This is the VAG scan:
What could be the root problem?
3 Faults Found:
4732 - Fuel Pump
P3045 00 [096] - Electronics Defective
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 88909 km
Date: 2016.04.13
Time: 15:06:03
4735 - Fuel Pump
P3044 00 [096] - Short Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 88909 km
Date: 2016.04.13
Time: 15:05:20
2838 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 88852 km
Date: 2016.04.12
Time: 18:01:04
3 Faults Found:
4732 - Fuel Pump
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 88909 km
Date: 2016.04.13
Time: 15:06:03
4735 - Fuel Pump
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 88909 km
Date: 2016.04.13
Time: 15:05:20
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 88852 km
Date: 2016.04.12
Time: 18:01:04
I think I am at the same point with my 2006 A6 C6. Unfortunately I went and replaced the fuel pump that was perfectly fine first. It is a different Fuel pump control module but same results. It was even blowing the 20A fuel pump fuse.
Too funny. My 2011 A4 Avant wasn’t running. I got it towed into the dealer. 55,000 miles, and the fuel pump is dead. I was amazed that only 5k miles past the 50k warrantee period it would start having issues - but the car is nine years old at this point?!?!
chobi
Q5/SQ5 MKI (8R) Discussion
21
04-22-2023 08:01 PM
mAgnum8
10-18-2008 06:10 PM
Vic995
10-28-2007 03:24 PM
