A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
2011 A4 Oil Leak all around Oil Pan
Old 02-20-2017, 06:17 PM
ilija's Avatar
Default 2011 A4 Oil Leak all around Oil Pan
Trying to figure out an oil leak all around the oil pan and oil lines. Any common issues to check for. Vehicle is a 2011 A4 Quattro
Old 02-05-2018, 06:30 AM
Khally's Avatar
Did you find out anything?
Old 02-05-2018, 04:29 PM
jfo
jfo's Avatar
Take a look above that area to the bottom of the turbo and locate the oil return line that goes from the turbo to the block. Look for the stainless steel band clamp around the turbo and the line is right beside it. You may be dripping oil from there.
Old 02-05-2018, 06:01 PM
ilija's Avatar
Turned out to be the front crank seal. I have not replaced it yet. I did first replace the upper timing cover gasket thinking that was the problem, but still leaks. I'm debating whether to get the front crank seal replaced, dealer, quoted $347, or getting the entire timing chain and guides replaced because of the failing tensioners in the early B8's. For the full timing chain job quoted $2100. Small independent shop quoted $1100.
Old 02-05-2018, 07:00 PM
jfo
jfo's Avatar
If it's the original tensioner, I'd strongly recommend getting it replaced. It is prone to failure and the results are very expensive! Once it's open you can decide on the chain and other parts. My 2011 chain has limited stretch after about 55K miles. The tensioner was done 2 years ago and I periodically check the extension of the piston through the inspection port on the lower cover.
Old 02-11-2018, 07:58 AM
Southernturbo606's Avatar
I'm trying to figure out an oil leak myself. So I had a bad pcv valve go bad and I put a bypass kit on. Now it's leaking oil. All the line on the bypass r tight. Is there maybe a line that needs to be plugged that could bypass the pcv valve so if it goes bad it can still run
silva
09-26-2019 09:55 AM
allroad(s) lead 2Gavin
Audi allroad
08-26-2006 07:04 PM
Hibiscus Red S4
05-31-2005 08:00 AM
Milpitas2.7T
13
10-14-2003 08:13 AM
AbnormallyAspirated
01-29-2002 04:26 AM
Quick Reply: 2011 A4 Oil Leak all around Oil Pan
