2012 A4 Mystery Ticking Sound from Under Car
I'm trying to find out if anyone has or has had the same problem that I am having with my '12 A4. September of 2015 I replaced both of the front rotors after driving in the mountains and having a horrible shake in the wheel when braking, and new rotors solved that problem.
Upon replacing the rotors I inspected all of the suspension components on the front end of the car and all seemed normal. After replacing the rotors I noticed that there was a ticking sound which was quick loud when driving, especially next to concrete barriers, buildings, or cars. I thought that this sound was from the new rotors, but through troubleshooting I determined it wasn't the rotors.
I've replaced a timing chain tensioner on my older '03 A4 myself, and immediately thought to check this for the sound and I was able to rule that out.
This noise isn't audible with the windows rolled up, and I had forgotten about it through winter, however it has been unseasonably warm now and I can definitely hear this noise again when driving around. It is quite loud and increases as my speed increases, however it doesn't increase when the wheels aren't moving. I parked my car in a quiet parking garage next to a wall to try and pin point the sound, and I've been able to hear the ticking begin when the engine is warm and I shift into reverse or into drive from neutral. It sounds like it is coming from the middle underside of the car. It only happens a little when the gear is first engaged, and then happens while driving.
If anyone has had this same sound before, or knows what might be causing it, I would greatly appreciate some assistance! I've been able to diagnose and fix most everything on my cars in the past, however this sound has me chasing my tail!
Thanks!
Thanks!
Digger Killer
08-30-2003 12:53 PM
Absltgreek (Mafia)
02-27-2002 07:47 PM
omidius
01-29-2001 12:05 PM
