3.2L Fuel Injectors Leaking
Hey guys!
Recently I bought a used 2009 A4 3.2L engine with only 30,000 miles. However I have been having start up issues every once in a while where the car would not start the first time but then would start the second try. This only happens 1/10 tries and more so when the car is still hot. There is no CEL on.
I took it in to the Audi dealership and they diagnosed that the problem was all 6 leaking fuel injectors. They figured that out by using a borescope through spark plugs.
My question is it possible that ALL 6 injectors are leaking or are they trying to make more money by replacing them all? Also would fuel injector cleaners work to stop the leaks? I believe the leaks are because the injectors can't close properly from carbon buildup but was wondering if you guys have any opinions on this matter. Also should I stop driving the car until this issue is fixed?
Hey guys!
I agree with jagtoes, it seems a little fishy that all 6 would go at once. Also your fuel pump could be bleeding off the pressure but this would be more pronounced at a cold start up when the vehicle has been sitting over night.
highlander69
10-21-2008 08:38 AM
Byblos
11-20-2002 03:14 AM
