ALL future Audis will be Front Wheel Drive! :(
#11
My understanding is that this new system is still reactive in unanticipated situations. For example you suddenly hit a slipper patch of road, or you are trying to start in deep snow. These FWD-biased "part-time" systems are fairly transparent as long as the computer can be proactive with engaging the rear axle, but when it reverts to reactive, that's when the flaws come out.
As to proactive vs. reactive, Audi describe the goal as:
The all-wheel drive system is activated before the driver needs it. In fact, all activations and deactivations follow a highly differentiated strategy.
The quattro electronics are networked with a number of other control units. Every ten milliseconds, the system acquires and analyzes a wide variety of data, such as steering angle, lateral and longitudinal acceleration and engine torque to name just a few. Activation of the all-wheel drive system follows a three-stage strategy: proactive, predictive, i.e. forward-looking, and reactive.
Audi quattro with ultra-technology ? Audi Technology Portal
The animation shows how the 2 clutches engage and disengage. It is a Torsen style system, and not hydraulic. The role of the clutches is just to isolate the propshaft and quattro gearing to reduce engine load. Audi do not mention whether there is a self-locking centre differential, nor do they mention torque splits.
The last paragraph is interesting - they point out the system is designed for manual and S tronic transmissions, as it requires a directly driven axle. Which means Audi will have a manual transmission option with quattro in the MLB2 platform, which they currently do not.
And the final point is that this is clearly described by Audi as an ULTRA system. Which means they may be replacing FWD Ultra with AWD quattro Ultra - a very smart decision if they do. Some earlier posters seem to think they were dumbing down the entire range of quattro drivetrains, but they are not doing this at all.
#12
I wonder if this is not Audi's way of getting out from paying Torsen licensing rights for a perfectly simple, proven mechanical AWD system? If it isn't broke, why are they trying to fix it, and really hiding the change in their marketing. No mention whatsoever.
#13
Further, this is from the Audi AG press release published on Audizine, specifically for the B9 A4 allroad:
"quattro all-wheel drive from Audi represents the ultimate plus in dynamics, traction, driving safety and straight-line stability. It is purely mechanical and thus operates with zero delay. quattro drive is partnered with the updated wheel-selective torque control system, which is active on any surface."
No mention of so-called Ultra-quattro. Where is this nonsense coming from?
#14
On a side note, the 6th generation Quattro system is not available with a manual transmission, that's why none of the new Quattro models (A4 and higher) are available with MT. MT is only available for the Haldex (A3 and lower) and FWD drivetrains.
#15
This blog states that B9 will use Torsen:
All-New 2016 Audi A4 Announced - YouWheel.com - Car News and Review
#16
Hi, do you have this information from a reliable source? It seems difficult to find out if the B8.5 (S-tronic) models have Torsen or Crown Gear centre diff.
#17
Yes, the B8.5 (S-tronic) has the crown-gear with torque vectoring. That's been in Audi literature. Don't have any links handy at the moment, though. This is the first I hear that they are going back to the Torsen C. That would seem to be a step back. The crown gear is superior in every way to the Torsen C.
I previously had a 2008 B8 (3.2FSI) (but obviously no active rear diff). I can sense a difference when the sport differential kicks in but it's not a night and day difference. I also have a problem with all descriptions of the Crown Gear differential that reports that the torque can be varied up to 85% to the back but in a following bullet states that it can "fully lock". If it could fully lock there is no reason why the torque distribution couln't go to a full 100% to the axle with grip.
#18
In what way is it superior? I have a 2014 3.0TFSI S-tronic with the active rear sport differential. In that sence I have torque vectoring, but I don't believe there is torque vectoring using the front brakes.
The crown gear is also lighter and smaller, so less rotational weight, resulting in a more responsive drivetrain and it is more rear biased 70/85 vs the Torsen's 80/80. Both diffs can send a 100% of the torque to either axle with the help of traction control, but that's a bit of a marketing gimmick, because if a 100% is sent to one axle that means traction control has to bring the other axle to a complete stop and then you are not moving anymore unless that axle is airborne or can slide on ice or another low friction surface.
The mechanical properties of the crown-gear also allows it to be better integrated with the car's electronics, which makes the 4-wheel brake based torque vectoring possible. By proportioning the brake force it applies to the inner front and rear wheels around a corner allows it to control how much torque is sent to the front and the rear when cornering, overall leading to much better and sportier driving dynamics. If combined with the sport differential, the brake based torque vectoring kicks in at higher threshold to aid with rotating the car when the sport diff cannot send more torque to the outer rear wheel on its own. At that point the inner rear wheel gets a braking torque applied which through normal diff action sends additional torque to the outer rear wheel and the inner front wheel also receives a braking torque to tuck in the nose of the car. This whole spiel allows for much faster cornering speeds, but obviously that only matters on a track or a deserted canyon road where you can explore the car's limits.
#19
But the statement "Because it is self-locking, it can send 85% of the torque to the rear axle even if the front axle has zero traction" is a contradiction. If one axle has zero traction (zero torque) and the other axle provides torque this means 100% and not 85%.
(I'm familiar with the rest of your text except some typos .. The rear bias is reported to be about the same for both, 40/60)
#20
This is a good video showing the new diff in action. Notice how the wheels on the rollers just gradually slow down as the clutch-pack locks up the center diff and more and more torque gets sent to the axle with more traction, but the spinning wheels never completely come to a stop. Traction control doesn't step in until the end where they put three wheels on rollers and then EDL needs to help in order to send torque to the one front wheel that has traction.
Was looking for this video for comparison. This is the classic BMW goof test showing how the torsen quattro is ineffective w/o traction control. They basically disabled traction control to make xdrive look superior.
