Audi Drive Select Individual setting MISSING in MMI
I own a 2009 A4 B8 PremPlus 3.2L (MMI 2G), which is equipped with ADS. It has buttons for Comfort, Auto, Dynamic, Individual on the center console, and when I bought that car a year ago, I had the option to customize the "Dynamic" setting in the MMI (it was the first entry in "CAR"). I never messed with it, but now I'm wanting to change it because I purchased a ross-tech cable and wanted to set Individual as my default ADS setting.
At some point between now and a year ago, it has completely disappeared from my MMI. I can still enable the Individual setting on the center console, but I cant customize it. I contacted Audi support and they confirmed that it should be there and that I should take it in for a software update.
I am saving that for my last ditch effort because the closest dealer is an hour away, they're charging for the upgrade, and I don't know if that will actually fix it. Has anyone had this issue? Anything I should try? (Already did factory resets) Thanks.
1) Have you changed anything with VCDS?
(Then the changes are logged in the VCDS folder \ debug).
2) Try the MMI-Restart command (the simultaneous 3 button press).
3) Just to check; you do have navigation?
2) Yep
3) Yep
On the note of the hidden menu, I went and checked of Charisma was disabled or something weird, but it was active. I tried disabling it, restarting, and reenabling it, still no go :/
Hassan2869
01-23-2017 02:28 PM
Lord Audi
01-13-2016 07:20 AM
Hassan2869
A6 (C7 Platform) Discussion
09-08-2012 11:58 AM
