AUDI TECH NEEDED, NO SPARK AFTER MOTOR SWAP
HI GUYS, PUT IN USED A USED MOTOR THIS WEEKEND AND WHEN I GOT IT IN IT WILL NOT FIRE. I AM NOT GETTTING ANY SPARK AT ALL, CHECKED ALL CONNECTIONS AND EVERYTHING IS HOOKED UP CORRECTLY. PULLED MOTOR BACK OUT CHECK HARNESS AND ITS GOOD.
JUST HAD THEY KEY MADE AND
HAVE NEVER FIRED IT UP WITH THIS KEY BEFORE.
ANYONE?
ANYONE?
Immobilizer? Did you have everything coded correctly? Best guess.
It may be the key but, It cranks and unlocks the doors and activates the alarm so my thinking is that it should be programmed, is this correct??? Also, i am not getting any spark whatsoever and one thing i should mention is that the map sensor was different on my motor from the one that was installed.
I am waiting on a new map senor which i ordered because the one on the new motor was broken and was from a Premium Plus car and mines is only a Premium car.
Could I not be getting spark due to a Map sensor? Map Sensor on the intake? ANYONE
All Sensors were replaced. Engine code CAEB on both motors. Some of them in fact were different. There were 4 different engine codes for the appropriated year range, 2009 to 2011. Getting my VCDS tool back from a friend tonight and will report my findings. In the meantime, any additional help is much appreciated, thanks..
Car was from same year and build date were only 3 days apart
ANYONE?
ANYONE?
Do you know you have to go through immobilizer procedures when you have a new key or ECU?
Read this.
Immobilizer - Ross-Tech Wiki
bigjeep_00
03-18-2006 11:06 PM
Twisted5000
9
02-12-2005 08:35 AM
tecknoquatt
13
08-05-2004 12:32 PM
