Buying a CPO 2013 A4 Premium Plus, anything to look out for?
Hey all,
I've decided to buy a CPO 2013 A4 Premium Plus with around 20k miles.
Is there anything I should look out for?
Also, is it the right decision to go CPO instead of just used?
Should I buy any of the maintenance or service plans? (Audi care, Audi care plus, Certified pre-owned contract plans, etc)
Hey all,
Hey all,
You will have warranty coverage for awhile, so that greatly reduces your financial risk and increases your enjoyment factor. The '13 model and newer seem to be rid of the various bugs that plagued earlier B8 A4's and they are very nice cars. I would suggest reading over the maintainance schedule closely - dealers will fleece you if you are not in control and you need to do what is called for, but not 400-500 worth of maintainance every time you drive in.
When you pick up the car, make sure that you take at least a 30 minute test drive over various terrain prior to signing the paperwork and DO NOT sign if it appears anything is amiss.
Hey all,
My $.02 after owning a variety of Audi, VW, etc.:
It's important to note that buying a CPO doesn't mean that the car hasn't been smashed. CPO means only that it strictly meets the criteria on the CPO checklist. Don't trust CarFax either. Their information is only as good as whatever is reported and available to them.
My take on Audi Care is that it economically makes sense if you intend to keep the car through the service intervals in the plan and intend to use dealer service. The Audi T&Cs (http://tinyurl.com/koyuetx) says that they don't pro-rate the cost if purchased later but I have heard they will. Read the T&Cs. There's a five-year max limit to reach the mileage that makes it a non-starter for people who don't drive a lot.
CPO is a solid value. There's real value in the reconditioning, inspection, and extended warranty.
- As others stated, review the CPO checklist. It is extensive. Anything close to exceeding wear tolerance for replacement can be challenged or negotiated.
- I would ask the dealer to see the detailed maintenance records. I've done this before and they have complied. They can redact (black out) any personal information on the records to protect privacy and still give you detailed service history.
- MOST importantly: I would take the car to a good body shop and have them inspect it. They can quickly tell you whether the car was in an accident that caused damage not easily visible on the exterior of the car (easily visible = panel seams of varying width, subtle misalignment of doors, etc.). You want them to look underneath.
I'm actually also in the market for a CPO right now and this thread has been helpful.
Regarding brake pad thickness, does anyone know how thick new ones are supposed to be? IIRC, CPO only requires them to be at 50% thickness or more.
cmpcpro
10-01-2011 09:37 AM
wfmlax11
07-18-2009 06:44 PM
