Drive Select with manual transmisison
I just got a base (Komfort in Canada) 2016 A4 with manual transmission. No MMI, no sport. Last manual A4 available. Being the last one off the line, it had S line trim as a freebie. One thing it has is Drive Select (button) and I can't figure out what it is supposed to adjust. There is nothing in the owner's manual to describe what it would do on a car with manual transmission. The only thing that I can figure it can change is the steering. I actually haven't got around to trying it yet but I was just (finally) reading the manual and didn't see anything. Anybody know that it does?
You should be able to find the following in the user's guide (Audi Drive Select):
You can toggle between the settings: Efficiency, Comfort, Auto, Dynamic.
Without furter ADS options the following is adjusted:
*Engine Response
*Steering (amount of assist)
*Klimat Control (Efficiency)
*Cruise Control (response)
If you have "Dynamic Steering" in addition to varying power assist also the steering directnes is speed dependent. Check if 1N8 is in your option code matrix.
If you have adaptive dampers, the code 1BL should be in the matrix.
*Engine Response
*Engine Response
*Engine Response
Why not. I had a manual (B8 08) with ADS. The engine response changed with the setting (both pedal sensitivity and less filterring). The air con and cruise control has nothing to do with gear box.
With automatic transmission the same setting adjust both engine response and gear change points. (Gear Sport mode can then be set On/Off separately with the gear selector.)
When I got my A4 it was the start of winter and I put (downsized 16") snow tires on immediately and haven't even thought of performance driving yet.
By the way, my manual has...
Engine/Transmission
Steering
Dynamic Steering*
Adaptive Dampers*
Sport Differential*
Adaptive Cruise Control*
Engine Sound*
Anything with an asterisk is not relevant to my car. Again, if they had put Engine and Transmission on different lines it would have been better.
musantemike
Audi A3 / S3 / RS 3 MKII
27
04-23-2015 07:10 PM
alanb1958
Other (Non-Audi) Autos Discussion
11-08-2009 09:01 PM
qezel
9
03-07-2008 06:20 AM
