Green menu help
Green menu help
Hello everyone,
I have 2015 A4 S line 3G plus and was messing around with the green menu. I should have taken the pictures before I modified anything but I did not.
It does not show the clock on my navi screen any more and some of the menu items are disabled now.
Anyway, does anyone know how to get back to the original setting? Is that even possible?
Thanks in advance.
Thanks in advance.
I presume you are talking about the hidden menu. If so, I see three options:
Find someone in your area who has enabled the hidden menu and compare settings.
If you know which menu items were changed you could post what they now show and see if somone cane help
Take your car to the dealer and have them reload the MMI software. Probably won't be covered under warranty if they see you made the changes.
This is a good example of why one should not make changes in Vag-Com or the hidden menu unless you log the original settings first and know what you are doing. Hopefully you didn't touch the "bootloader" option. That would bork your MMI which could result in a replacement.
Hi Dan,
Thanks for your offer.
If you could, please take the screen shots for the following:
/car/cardevicelist
/car/carmenuoperation
/car/carbusassignment
/car/carprotocoliswitch
thanks for your help!
/car/cardevicelist
DanD,
Thank you very much! I was able to compare mine against your pictures and was able to restore my system!
Once again, thank you so much!
